D Orbitals: Are There 5 or 6 Valid Solutions?
  • Context: Undergrad
  • Thread starter Thread starter HellFeuer
    Orbitals
The discussion centers on the nature and number of d orbitals in quantum mechanics, specifically whether there are 5 or 6 valid solutions to the Schrödinger equation related to d orbitals. Participants explore the implications of linear combinations of wave functions and the physical interpretation of these orbitals.
  • Some participants assert that there are 5 d orbitals corresponding to the quantum number m = -2, -1, 0, +1, +2.
  • Others introduce the idea that there could be 6 possible solutions to the Schrödinger equation, with the d z-square orbital being a linear combination of two of these solutions, leading to the effective count of 5 orbitals.
  • One participant questions the meaning of two orbitals having "no independent existence" and how this affects the classification of orbitals.
  • Another participant explains that linear combinations of wave functions are valid due to the linear nature of the Schrödinger equation, suggesting that while there are infinite combinations, only five distinct d orbitals are necessary to describe the system.
  • A participant expresses interest in exploring different linear combinations of d orbitals in relation to tetrahedral symmetry and how this might affect their representation.
  • One comment prompts a deeper inquiry into why there are specifically 5 d orbitals associated with the quantum number.
Participants exhibit disagreement regarding the total number of valid d orbitals, with some supporting the traditional view of 5 orbitals and others suggesting the existence of 6. The discussion remains unresolved as differing interpretations and hypotheses are presented.
Participants express uncertainty about the implications of linear combinations of orbitals and the physical meaning behind the existence of orbitals that may not be independent. There are also unresolved questions about the mathematical and physical constraints that define these orbitals.
HellFeuer
d orbitals.. 5 or 6?
hey
i always thought ther wer 5 d orbitals corresponding 2 quantum number m = -2, -1,..., 2
now i read somwhere that ther wud actually be 6 possible sollutions to schrodigner's equation.. i.e. six d orbitals, and th d z-square orbital is a linear combination of two of these 6, giving effectively 5.
it also says that this combination is done because the two orbitals that are combined 'have no independent existence'
firstly,, is this true? (th place i read this is not exactly reliable)
secondly, if it is, then how can 2 of these 6 orbitals 'have no independent existence'? wt does this mean?
if it does not have independent existence, then wt meaning is ther 2 calling it a separate orbital
also, if ther wer 6 orbitals, shudnt ther be a possibility of 12 d electrons?
i thot that every valid solution to schrodingers equation(provided it satisfies those 3-4 constraints, continuos, finite etc) is in fact physicaly possible??
thnx.. i know nothin of quantum mechanics so sorry if i asked some ****
HellFeuer
HellFeuer said:
hey
5 should be indeed.
HellFeuer
WHERE??
Daniel.
you can always make linear combinations of wave functions, because the Schrödinger equation is linear. If you write down two different wave functions psi1 and psi2, with the same energy value (ie, both have the same n value for hydrogenic orbitals), then a*psi1 + b*psi2 is a solution with the same energy value, for any constants a and b.
The usual px, py, pz orbitals that you see in chemistry textbooks are linear combinations of the l=1 states that you normally get when solving the hydrogen atom.
Making a linear combination of solutions does not give you "more" solutions, because the solutions form a complete set. You can form any state with l=2 by taking a linear combination of d-orbitals (ie. you can form the states m = +2,+1,0,-1,-2 projected on any axis you want by adding up the usual d-states). So to answer your question, there really are an infinite number of solutions with l = 2, because you can combine solutions. However, you only need five solutions because then you can form any other solution.
kanato! you seem like someone getting the picture with the linear algebra involved in orbital theories!
have you seen any different linear combinations of the d orbitals than the usual xy,yz,zx,x2-y2 and z2 set? Hope this is not too OT... but I would like to see what it looked like if one symmetry-adapted the 5 d-orbitals to e.g. tetrahedral symmetry, i.e. one set (don't remember if it was the t or the e set) having tetrahedral symmetry and the other set actually having no tetrahedral symmetry (which would be nonbonding in the tetrahedral field). In other words I would like to have some sort of picture of what the d orbitals would look like in order to account for the t+e splitting in a tetrahedral ligand field, some sort of purely d-orbital precursors to the t and e set that are obtained after bonding with the ligands.
Hope my question is understandable. And if it's OT please send me a pm if you can tell me more!
My thought was just: if on is free to decide which linearly independent set of orbitals one uses to describe, why not explain e.g. tetrahedral bonding with a representation of the d-orbitals which clearly shows one set with tetrahedral symmetry and one set without?
What you really should ask yourself is : why are there 5 d-orbitals that each correspond to this quantumnumber ?
euuurrr
marlon
  • · Replies 54 ·
  • · Replies 26 ·
13K
  • · Replies 50 ·
13K
  • · Replies 24 ·
