Register to reply
Vacuum conductance calculation, tube closed by a disc.
by vst98
Tags: calculation, conductance, disc, tube, vacuum
Share this thread:
vst98
#1
Apr23-13, 07:32 AM
P: 32
Hi !
I'm trying to calculate a conductance for free molecular flow of a tube which is closed by a disc. The distance between the tube and the disc will be approx 10 micro meters while inner and outer radius of the tube is around r1~10cm ; r2~20cm.
Here are some pictures: http://tinypic.com/r/5mjsbd/4, http://tinypic.com/r/2zi4eus/4
The conductance of the tube is given in most textbooks on this subject, but I don't know how to find a conductance of a volume enclosed by the disc and the wall thickness (r2-r1) of the tube.
My first idea was to approximate the enclosed volume by rectangular tubes and then integrate the relation for rectangular tube conductance from 0 to 2*Pi*r2, that is:
[itex]\int[/itex][itex]^{2*Pi*r_{2}}_{0}[/itex](31.1[itex]\frac{b^{2}*c^{2}}{(b+c)L}[/itex])db
where c is the rec. tube height, b ist the tube thickness and L=r2-r1 is the length of the tube.
But I'm not sure whether this is good.
Phys.Org News Partner Engineering news on Phys.org
DIY glove-based tutor indicates muscle-memory potential
Tricorder XPRIZE: 10 teams advance in global competition to develop consumer-focused diagnostic device
Study shows local seismic isolation and damping methods provide optimal protection for essential computing equipment
Register to reply
Related Discussions
Why can't holomorphic functions be extended to a closed disc? Topology and Analysis 11
Could open tube and closed (at one end) tube produce the same frequency? Introductory Physics Homework 5
How does a vacuum tube get hot? General Physics 10
Harmonics of a closed-closed tube... General Physics 2
Vacuum Tube General Physics 10
