Circular Motion of two objects
The discussion centers on the circular motion of two wooden objects, each with a 1kg weight. Object 1 spins perfectly when torque is applied, while Object 2 wobbles due to unbalanced centripetal acceleration. The centripetal acceleration is defined by the formula c=(v^2)/r or c=(w^2)r, where v is linear velocity and w is angular velocity. The wobbling of Object 2 indicates a lack of uniform motion, attributed to its design or mass distribution.
  • Understanding of torque and its application in rotational motion
  • Familiarity with centripetal acceleration concepts
  • Knowledge of angular velocity and its relationship to linear velocity
  • Basic principles of physics regarding mass distribution in rotating bodies
  • Study the principles of torque and its effects on rotational dynamics
  • Learn about the factors affecting centripetal acceleration in rotating systems
  • Explore the relationship between angular velocity and linear velocity in circular motion
  • Investigate the impact of mass distribution on the stability of rotating objects
Physics students, mechanical engineers, and anyone interested in understanding the dynamics of rotating systems and the effects of torque on motion.
Exidez
i have a question which i have been told about but i still don't udnerstand...
ok..
you have two objects(say they are made out of wood):
1: *-------------* ... 2: *---------
"*" represents 1kg wieghts
"..." represent nothin, i needed to put those there so the picture would position correctly. Just say it is open air :)
you supply a torque to object number 1, you will notice that is spins perfectly. While if you supply a torge to number 2 it will wobble and isn't perfect like number 1.
so what i want to know is.. why does number 2 wobble?
its hard to explain the question, but i hope you all understand
also the torque is supplied at the rod:
Number two wobbles because there is an unbalanced centripetal acceleration. Given a point mass at radius r, and instantaneous velocity v, centripetal acceleration c is given by:
c=(v^2)/r
or if you use angular velocity (w is omega):
c=(w^2)r
In case you usually use rpm, I think v=rpm*Πr/30 and w=rpm*Π/30.
  • · Replies 24 ·
