Source-free 2nd order lin. circuit
  • Thread starter Thread starter EvLer
    2nd order Circuit
The discussion centers on the analysis of a source-free RLC second-order linear circuit, specifically the relationship between the voltage across the capacitor, Vc(t), and the current through the inductor, iL(t). Both variables are governed by the same differential equation: L\ddot x(t) + R\dot x(t) + (1/C)x(t) = 0, leading to identical characteristic equations and solutions. The roots of the characteristic equation are the same for both Vc(t) and iL(t), confirming that their solutions share the same form, differing only by constants. Thus, in a source-free circuit, Vc(t) and iL(t) are indeed equivalent.
  • Understanding of RLC circuit theory
  • Familiarity with differential equations
  • Knowledge of damped harmonic oscillators
  • Basic concepts of impedance in electrical circuits
  • Study the general solution of second-order linear differential equations
  • Learn about the characteristics of damped harmonic oscillators
  • Explore the concept of impedance in RLC circuits
  • Investigate the relationship between voltage and current in AC circuits
Electrical engineers, physics students, and anyone studying circuit analysis or RLC networks will benefit from this discussion.
EvLer
RLC second order linear network question:
So, we are given this equation which is the same for Vc(t) and iL(t) expressed as x(t):
2nd deriv of x(t) + R/L(1st deriv of x(t)) + 1/(LC)(x(t)) = 0;
And in one of the problems it asks to find both equation for the Vc(t) and iL(t) for t < 0, and now I am confused, it seems to me that they are the same, since the solution is the same for both of them:
aS^2 + bS + c = 0;
because the coefficients are the same from differential equation, so there are the same roots for Vc(t) and iL(t), and roots are w/t imaginary part, just reals.
Am I wrong?
Thanks a lot.
I am not sure I understand what you are asking exactly, but perhaps this will help.
An LC circuit with resistance is simply a damped harmonic oscillator. The differential equation:
[tex]L\ddot x(t) + R\dot x(t) + \frac{1}{C}x(t) = 0[/tex]
has the general solution:
[tex]x = A_0e^{-\gamma t}sin(\omega t+\phi)[/tex]
where [itex]\omega^2 = \omega_0^2 - \gamma^2[/itex] and
[itex]\omega_0^2 = 1/LC[/itex] and
[itex]\gamma = R/2L[/itex]
The relationship between V and I in an RLC circuit is:
[tex]V = IZ[/tex] where is the impedance: [itex]Z^2 = R^2 + (\omega L - 1/\omega C)^2[/itex]
AM
You are correct in thinking that the equations for Vc(t) and iL(t) are the same. This is because in a source-free circuit, the voltage and current are related by the same differential equation.
In this case, the solution to the differential equation will be the same for both Vc(t) and iL(t). This is because the circuit elements (resistor, inductor, and capacitor) are the same for both variables, so the coefficients in the differential equation will be the same.
Therefore, the roots of the characteristic equation will also be the same for both Vc(t) and iL(t). This means that the solutions for Vc(t) and iL(t) will have the same form, just with different constants. This is why you see the same solution for both variables.
So, in conclusion, you are not wrong. The equations for Vc(t) and iL(t) will be the same in a source-free circuit, and this is because of the relationship between voltage and current in this type of circuit.
