Find work done in stretching rubber band
by inter060708
Tags: band, rubber, stretching, work
inter060708
inter060708 is offline
#1
Apr26-13, 12:06 AM
P: 16
Please see attachment.
2. Relevant equations
3. The attempt at a solution
Not really a homework problem. This is 1 of my exam question which I believe I had the right answer but my professor insists that he has the right one.
I started by equating work done, W = integral F ds, with limit of integration from 0 to Lo. My professor's integral has limits from Lo to 2Lo.
If I am correct, please tell me how I can explain it to my professor. If not, explain to me why.
Thank you very much.
Phys.Org News Partner Science news on Phys.org
NASA's space station Robonaut finally getting legs
Free the seed: OSSI nurtures growing plants without patent barriers
Going nuts? Turkey looks to pistachios to heat new eco-city
NascentOxygen
NascentOxygen is offline
#2
Apr26-13, 12:50 AM
HW Helper
P: 4,715
It seems clear that s goes from 0 to lo. But are you sure your prof didn't simply substitute ❲s+lo❳with another variable, say, x, where x goes from lo to 2.lo?
inter060708
#3
Apr26-13, 12:56 AM
P: 16
No substitution were made. He did it everything the same way except for the limits of integration. How can I explain to him?
ehild
ehild is offline
#4
Apr26-13, 12:59 AM
HW Helper
Thanks
P: 9,818
The problem text says that s is the length the band is stretched by beyond the unstretched length Lo.
ehild
crashdirty86
crashdirty86 is offline
#5
Apr26-13, 01:40 AM
P: 21
Quote Quote by inter060708 View Post
If you get a rubber band, does it already sit at full length or is it laid in some weird oblong shape? In my mind, you would be doing some small amount of work to have the rubber-band laid out in a way to measure its full, unstretched, initial length. From this perspective, you then begin to stretch the rubber-band twice its length, so technically the force stretching the rubber band starts at the initial length and then commences at twice its length. This would be the distanced used to integrate the work done by the force on the rubber band.
inter060708
#6
Apr26-13, 02:35 AM
P: 16
Quote Quote by crashdirty86 View Post
I am sorry, but in this case, are you saying that my prof's limit of integration is correct?
I understand that you need reference length for the force to be acting, but putting the initial limit of integration as something other than 0 would mean that you have stretched it beyond its natural length.(since 's' in the 'ds' is the amount of stretch)
haruspex
haruspex is offline
#7
Apr26-13, 02:44 AM
Homework
Sci Advisor
HW Helper
Thanks ∞
P: 9,162
Not sure what crashdirty86 is saying, but everyone else so far, me included, agrees with you: s goes from 0 to L0.
NascentOxygen
#8
Apr26-13, 03:35 AM
HW Helper
P: 4,715
Putting the shoe on the other foot?
If trying to convince a disbelieving student, I might try this approach:
Suppose you nominate some realistic data values (for Fo, lo, and s) and plot the graph F vs. s. (Surely your prof would agree that the work done is represented by the area under the graph.)
Then all that remains is to have his show whether his integral evaluates to the same answer as that graphical area, or yours.
But, most likely he is just having a senior moment. After a restful night's sleep he'll probably smack his forehead and wonder what on earth he was dreaming about to say it so wrong.
Dadface
Dadface is online now
#9
Apr26-13, 04:27 AM
PF Gold
Dadface's Avatar
P: 2,002
F equals zero when s equals zero so don't both sets of limits give the same answer? If F is finite when s is zero then the professors answer would be correct. However, F is not finite for zero s so for this particular problem it doesn't matter which of the two sets of limits is used. I think I may be missing something here.
NascentOxygen
#10
Apr26-13, 11:10 AM
HW Helper
P: 4,715
Is your professor someone for whom English is not his native language?
" ... s is the distance the rubber band is stretched beyond its natural length." could be confusing, though comparison with any ordinary spring should clear it up in his mind.
Register to reply
Related Discussions
Rubber band General Physics 7
Stretching or Compressing a Spring; Given work, find the displacement of the object Introductory Physics Homework 9
rubber band Classical Physics 0
hot rubber band Classical Physics 5
God I Need help or (Rubber band stretching) Classical Physics 21
