Can you use a dc circuit in a transformer?
The discussion revolves around the use of a DC circuit in a transformer, exploring whether transformers can function in such circuits and the implications of using DC versus AC. Participants examine the operational principles of transformers, including the role of magnetic fields and current changes.
  • Some participants question whether a transformer can be used in a DC circuit, suggesting that while it can be connected, it will not function as intended and will behave more like a coil of wire.
  • There is a discussion about the use of interrupted DC circuits, with some suggesting that devices like buzzers can create the necessary conditions for inducing current in the secondary winding through collapsing magnetic fields.
  • One participant clarifies that a straight DC current does not induce current in the secondary unless it is interrupted, leading to a single pulse rather than continuous output.
  • Concerns are raised about the noise produced by transformers, with some attributing it to the vibrations of metal plates within the transformer and the mounting methods used.
  • There is a debate about the fundamental principles of how transformers work, with references to magnetic fields and the role of electric current in generating these fields, as well as discussions about the interpretation of these principles.
  • Participants express uncertainty about the complexities of electromagnetic theory, with references to Maxwell's equations and the relationship between electric and magnetic fields.
Participants do not reach a consensus on the use of transformers in DC circuits, with multiple competing views on how transformers operate and the implications of using DC versus AC. The discussion remains unresolved regarding the nuances of electromagnetic principles.
Some participants mention limitations in their understanding of the principles involved, indicating that the discussion may not cover all necessary assumptions or definitions related to transformers and electromagnetic theory.
T@P
can you use a dc circuit in a transformer? will it work the same way?
I think your question is: can you use a transformer in a DC circuit? The answer is 'yes', but it won't act like a transformer. It will act like a coil of wire and will get hot if you put much current through it. And you will get an arc when you open the switch (due to the self inductance). There will be no current in the secondary [Edit: except when the DC current in the primary is changing - eg. when you open or close the switch]
AM
Won't it work in an interrupted DC circuit, as having a buzzer or such like in series, because the collapsing field is what induces the secondary?
You are quite right that a transformer can be used in an interupted DC circult. That is, after all, how a coil works in a car engine. It turns 12 V into the high voltage needed for the spark.
But I don't think a buzzer uses a transformer. It simply uses a relay that pulls a switch on loaded spring that then cuts off the current to the relay and the cylce repeats.
AM
My fault for being lazy. I was sort of short-handing my post. What I meant was that you could use something like a buzzer in the circuit to interrupt it (like the points in a car) and thus obtain a transformed, but not steady, DC voltage.
oh so i need an ac circuit for a transformer... i see. thanks.
No... no. Sorry if that was a bit misleading. The way a transformer works is that the primary circuit around the armature sets up a magnetic field. That field collapses when the current is removed, and at that point induces a current in the adjacent secondary windings. A straight DC current is never removed, and so doesn't do anything. If you shut it off, you get one very quick pulse at the secondary. An oscillator, buzzer, etc. continuously makes and breaks the circuit, and every time it's broken you get a pulse. Make the interruptions close enough together, and you get a pulsed current at the output which in most practical cases is smooth enough to use. The reason that AC is used most of the time is that it's already pulsing @ 60Hz, and therefore needs no additional components such as breaker points.
Thanks for the clarification. is that why some transformers make a lot of noise? (the buzzer going on and off?)
I heard it is because the continuous crashing and vibrating of the metal plates of which the magnetic nucleus is formed. As alternating magnetic flux gets through the nucleus, it provokes magnetic forces inside it which make internal vibrations of such compilled plates.
The transformer buzz itself is often amplified as well, since it's probably mounted solidly (screws, etc.) to a larger structure to which the vibrations are transmitted. It's a lot quieter if you mount it on stand-offs of some shock-absorbent type.
Danger said:
...the collapsing field is what induces the secondary?
It is a little more complex than that. For example, the secondary can be in a region where there is never any magnetic field. Take a look at post 48 and 50 of thread "first stars - how big - black holes now?" (in the cosmology section) to see specific design with no magnetic field ever present near the secondary coil and to understand better how a transformers really works. That off thread bit about transformers was to show that people often accept without thinking "feel good" words that have nothing to do with what is really happening - In case of tranformers, many believe that "lines of flux cutting thru the secondary" cause the secondary current. Some who believe this even know that these "field lines" are not even real. They were invented by Faraday, and he knew they were not real, only an aid to thought.
You've just been lying in the weeds waiting for me to do that, haven't you? :biggrin: It's all very cool, and I don't have time to read it right now, but it doesn't really impact the original question here. For practical purposes of sticking a transformer into a circuit, the collapsing field is adequate. :-p
I got overwhelmed by the posts in the cosmology section...
correct me if I am wrong, but isn't the principle of a transformer that a changing electric field makes a magnetic field, (the AC current through the first coil), and the flux through the second coil produces an EMF in that coil. in relation to the "feel good" words described by the author of posts 48 and 50 (sorry i don't remember), i just don't see them. can anyone explain? sorry if I am a stubborn learner, but this is all kind of new to me.
Your understanding of a transformer is basically correct, T@P - except that it'd be better to say that an electric current causes a magnetic field. A changing electric field does also generate a magnetic field, but this is important in capacitors, not in transformers. Ind transformers it's the current that causes the magnetic field.
As far as Bill_T's point goes, don't worry about it too much. He's just saying that if you concentrate the magnetic field, you can have a net magetic flux through a loop of wire without having the magnetic field intersect the copper. But the magnetic field doesn't have to intersect the copper, it just has to pass through it.
How does the current cause the magnetic field ?
This question is beyond the scope of this thread and probably should be a new thread. It is not a trivial question and can the answer can have as much depth as you want. The answer has to do with Special Relativity.
AM
either that or you can point to maxwell's equations and laugh.
Maxwell's equations describe the magnetic field and quantify it, but do not explain how it arises.
AM
ok you win :) theyre just funny especially since they look so menacing with all the integrals =)
Go check out GD. Anything involving Integral is menacing. :wink:
Of course, he'll probably delete this post... :frown:
  • · Replies 35 ·
12K
  • · Replies 17 ·
  • · Replies 18 ·
