Graph of Tension force vs. the square of the speed
by rstat1
Tags: force, graph, speed, square, tension
rstat1
rstat1 is offline
#1
Apr27-13, 03:59 PM
P: 4
Working on a physics lab report regarding uniform circular motion, one of the questions asks to graph the Tension Force vs. the square of the speed. Another part of the same question asks what the slope of the graph represents, which is where I'm stuck.
2. Relevant equations
3. The attempt at a solution
Phys.Org News Partner Science news on Phys.org
Lemurs match scent of a friend to sound of her voice
Repeated self-healing now possible in composite materials
'Heartbleed' fix may slow Web performance
FireStorm000
FireStorm000 is offline
#2
Apr27-13, 04:13 PM
P: 169
Your graph, or a table of values would definitely qualify as known data, so you should post those. If you did any theory work before this, you probably also have at least one equation you think is related (IE: one with an acceleration or force term, and a V^2 term). We want to help you work through the problem rather than just giving the answer.
rstat1
rstat1 is offline
#3
Apr27-13, 04:19 PM
P: 4
Quote Quote by FireStorm000 View Post
My problem was determining what the slope represented. My graph and associated data is in the attached excel file.
As far as equations, I don't even remotely know which would be useful: I've got one for calculating the speed (v = 2pi/T) and one for one for Tension force (M*g)
FireStorm000
#4
Apr27-13, 04:26 PM
P: 169
My problem was determining what the slope represented. If you still want my graph/data then in its in the attached excel file.
Alright, I took a look at your data and I think I see why you're having trouble. Can you identify the independent and dependent variables in your experiment? It looks like you varied something besides velocity.
rstat1
rstat1 is offline
#5
Apr27-13, 04:41 PM
P: 4
I only included the data used to make the graph because I thought that was all that was relevant as far as my question was concerned. The experiment focused on timing how long various masses (starting from 50g and going to 135g) would take to make 20 revolutions. So yes I did vary something besides the velocity, the mass was also varied.
FireStorm000
#6
Apr27-13, 05:07 PM
P: 169
You should find that the slope has something to do with mass
rstat1
rstat1 is offline
#7
Apr27-13, 05:14 PM
P: 4
Well yea I knew that, since the graph is tension force vs speed. I had thought you asked what else I varied.
FireStorm000
#8
Apr27-13, 05:44 PM
P: 169
Quote Quote by rstat1 View Post
Yeah, I was wondering why your graph was all over the place.
The equations you're looking for is:
Actp = r * v 2
and so
Fctp = m * r * v2
Now, I assume r is constant in your setup, so the mass is what changes the ratio of F to V2
Because of that, the slope of any given line segment should show the relative mass between the two data points, if that makes any sense.
Register to reply
Related Discussions
Conical Pendulum, find tension, radial force, speed, period, and angular speed Introductory Physics Homework 1
Finding speed from force-vs-position graph Introductory Physics Homework 2
Calculating the final speed using Force/Time Graph Precalculus Mathematics Homework 12
Plot a graph to verify the inverse square law and use the graph to estimate...? Advanced Physics Homework 1
Centripetal Force / Tension / Speed Introductory Physics Homework 5
