Will These Motors Be Powerful Enough?
  • Thread starter Thread starter rocketbuilder
    Motors
The discussion revolves around the adequacy of specific motors for a rover project, focusing on the rover's ability to move and climb slopes. Participants explore the torque and power requirements necessary for the rover to operate effectively in various environments, particularly concerning its weight and wheel specifications.
  • One participant inquires whether six 12 Volt DC motors with 120 RPM and 60 Newtons * cm of torque are sufficient for a rover weighing 15-18 lbs, emphasizing a slow walking pace and the ability to navigate small hills.
  • Another participant asks for the maximum slope the rover is expected to climb, indicating the importance of this factor in determining motor adequacy.
  • A later reply suggests using geometry and potential energy equations to calculate the power required for climbing a specified slope, recommending the inclusion of an efficiency factor.
  • The original poster shares their calculations, estimating a force requirement of about 2.25 lbs per foot for climbing a 35-degree slope, and questions whether wheel diameter should be considered in torque calculations.
Participants have not reached a consensus on the adequacy of the motors or the calculations presented. Multiple viewpoints regarding the necessary calculations and considerations for torque and power remain evident.
Participants have not fully resolved the assumptions regarding efficiency factors, the impact of wheel diameter on torque, and the specific calculations needed for power requirements.
rocketbuilder
Hi everyone,
I plan on getting a deeper understanding of this soon, but for the time being I'm just looking for a quick answer so I can order the parts needed.
I'm building a rover that in total (including all parts) will weigh about 15-18 lbs. It has six equally spaced legs, each connected to a 4.5 inch diameter by 3 inch wide wheel with rubber treads. Each wheel has a small hub connected to it where the 4mm shaft of the motor will be held. My question is, will 6 small 12 Volt DC 120 RPM motors with 60 Newtons * cm of torque be enough to move the rover around? I'm not really concerned with speed as long it can move at about a slow walking pace. My bigger concerns are will it move and will there be enough torque for it to make it up small hills of modest inclination (given that it has some traction).
Thanks so much
Welcome to PF!
What slope are you looking to try to climb?
Thank you!
I guess there really isn't one set slope that I want the rover to climb. I want it to be able to move around in different environments, but let's just say the maximum slope it would try to climb would be about 35 degrees.
thanks again
Ok, can you use some geometry and the equation for potential energy to calculate the power required to do that? (And throw in an efficiency factor of 50%.) Then you can use that power and the RPM to find the torque required of the motors. Give it a shot...
Ok, so I did some calculating and ended up with about 2.25 (rounding up a bit) lbs force per foot for the torque needed to climb a slope of 35 degrees and a height of about 5.73 ft given it's hypotenuse is 10 ft. I also took into account the 50 percent EF when calculating the power. Do these numbers sound somewhat correct? Also do I have to take into account the diameter of the wheels? My formula for calculating torque was T= hp(converted from power) X 5252 / rpm
10K
  • · Replies 19 ·
