Biochemical structure of dominant vs recessive gene
  • Thread starter Thread starter Murdstone
    Gene Structure
The discussion revolves around the biochemical differences between dominant and recessive genes, exploring their structural variations, mechanisms of action, and the implications for traits they influence. Participants delve into the nature of alleles, mutations, and the functional outcomes of these genetic variations.
  • Some participants propose that the recessive gene may be a mutation that codes differently for a protein, potentially not coding for a protein at all or coding for a different variant of the protein.
  • Others argue that the dominant allele does not simply silence the recessive allele; instead, it overpowers it, leading to the expression of the dominant trait when at least one dominant allele is present.
  • A later reply introduces the concept of dominant negative alleles, where the protein produced by the dominant negative allele interferes with the function of the protein produced by the recessive allele.
  • Some alleles may contain mutations that do not alter the protein itself but affect regulatory regions, as illustrated by the example of lactose intolerance and lactase persistence.
  • One participant suggests that the primary difference between dominant and recessive alleles lies in their functional efficacy, with one operating at full capacity and the other at a reduced level.
Participants express varying views on the mechanisms behind dominant and recessive traits, with no consensus reached on the biochemical specifics or the implications of these differences.
Limitations include the lack of clarity on specific biochemical pathways, the dependence on definitions of dominance and recessiveness, and unresolved questions regarding the nature of mutations and their effects on protein function.
Murdstone
Most all familiar with the terms dominant and recessive trait in a general way. I have seen little on the biochemical difference.
Assume
1. Gene codes for characteristic
2. Variance in characteristic due to sequence within gene
How does the structure of an allele differ from an actual different gene?
What is the biochemical mechanism behind dominant vs recessive?
Biology news on Phys.org
How forgetful. I see I have dwelt on the question before. However, this time, after reflection, I have a better understanding of the process. The "recessive" gene is a mutation that codes differently for a protein. It might not code for a protein at all or it might code for a different "flavor" of the protein. So the gene itself is not the determinate of the trait. It is a precursor to the protein, with the protein being the tangible component that determines the trait.
To clarify. I was thinking that when a dominate and recessive gene "meet", that the dom silences the rec and that is it. Not so.
In most cases this is true. When an individual contains both a recessive and a dominant allele, it is usually not the case that the dominant allele interferes with the function of the recessive allele. Rather, the dominant allele just "overpowers" the recessive allele. For example, if the dominant allele encodes for a certain color pigment and the recessive allele encodes a lack of pigment, the individuals will show pigmentation whenever they have at least one dominant allele and will only lack pigmentation when they have two recessive alleles.
An exception here would be the case of a dominant negative (DN) allele, but here the "silencing" occurs at the protein level where the protein produced by the DN allele will prevent the protein produced by the recessive allele from functioning correctly.
Some alleles contain mutations in regions that do not change the protein itself. For example, consider lactose intolerance. Early humans, like most other mammals, have the ability to digest lactose only in early age and this ability goes away in adulthood. Sometime in human evolution, a mutation occurred near the gene encoding the lactase enzyme responsible for digesting lactose. This mutation did not change the protein, but rather, it changed the regulatory DNA around this sequence, preventing the gene from being turned off in adulthood. The result here is the lactase persistence allele, a dominant allele encoding the lactose tolerance trait.
Thus, here is an example where the dominant allele of the lactase gene is the mutant form, not the recessive allele. Furthermore, the different flavor of the lactase gene differs not in the protein produced but in how the protein gets turned on and off during development.
Assume
To simplify things other than chemical differences, the true difference between the two is in terms of function. One works at 100% efficacy, the other works less.
  • · Replies 16 ·
33K
