Simple question on Conservation of Momentum and KE
The discussion revolves around the concepts of conservation of momentum and kinetic energy (KE) in the context of inelastic collisions. Participants explore the relationship between these conservation laws and the implications of energy loss during such collisions.
  • One participant expresses confusion about how momentum can be conserved when kinetic energy is not conserved in an inelastic collision, given that both depend on mass and velocity.
  • Another participant clarifies that momentum conservation applies to the system as a whole, not to individual bodies, and notes the difference in how momentum and kinetic energy are calculated.
  • A further comment emphasizes that momentum conservation does not derive from energy conservation, highlighting their independence.
  • One participant acknowledges a misunderstanding, previously believing that momentum conservation was a consequence of energy conservation.
  • A later reply suggests that at a fundamental level, the laws of momentum and energy conservation are interconnected, but classical mechanics imposes specific conditions for their application.
Participants exhibit a mix of agreement and disagreement. While there is consensus on the independence of momentum and energy conservation, there is ongoing debate regarding the implications of these principles in inelastic collisions and the participant's understanding of their relationship.
Some participants note that the discussion hinges on the definitions of energy and momentum, as well as the conditions under which these conservation laws apply, particularly in the context of dissipative forces.
This discussion may be useful for students and enthusiasts of physics seeking to understand the nuances of conservation laws in mechanics, particularly in the context of collisions.
Crumbles
I am having a bit of a conceptual problem with the conservation laws.
Consider a system of two bodies of mass m each. One moving at speed V1 towards the second body which is at rest.
For the case of an inelastic collision, I understand that the total kinetic energy of the system is not conserved but the total momentum of the system is.
What is bugging me is how can this be if both KE and the momentum, P depend on the mass and velocity of the body.
If the KE before and after the collision is different, how can the momentum which also depends on m and v be the same?
In the case of an inelastic collision, energy is lost to the surroundings: if momentum conservation stems from the conservation of energy, how can the momentum be conserved?
Nope,conservation of momentum is a direct consequence of Newton's principles applied to isolated systems.However,the conservation on energy is true only for a restrained class of systems,namely conservative systems,for which the interaction forces are derived from a potential field...Dissipative forces are not derived from a potential field.
Daniel.
Right.
Two comments: (1) It's the momentum of the system that's conserved, not the momenta of each body. (2) KE and momentum depend on the velocites in very different ways: momentum is a vector while KE is a scalar. To find the momentum of a system of two bodies you need to add the individual momentum vectors of each; if they point in opposite directions, they can cancel each other. But to find the KE of a system of two bodies, just add the KE of each; they always add, never cancel.
See above.
Two more comments: (1) In an inelastic collision between two bodies, mechanical energy is "lost" to thermal energy, deformation, sound, etc. (2) Conservation of momentum does not stem from conservation of energy! They are independent.
Thanks for explaining this. I always thought that the law of conservation of momentum was from the law of conservation of energy.
At fundamental level (elementary particles) these laws go hand in hand,though...But classically,there are certain conditions which must be fulfilled.
Daniel.
  • · Replies 53 ·
  • · Replies 21 ·
  • · Replies 52 ·
  • · Replies 30 ·
  • · Replies 25 ·
