Parametric equations for a circle
The parametric equations for the circle defined by (x-3)^2 + (y-4)^2 = 9 are x = 3 + 3cos(t) and y = 4 + 3sin(t). The center of the circle is located at (3, 4) with a radius of 3. As the parameter t increases, the circle is traced in a clockwise direction. The correct formulation for the y component, considering the clockwise tracing, is y = 4 + 3sin(-t) or equivalently y = 4 - 3sin(t).
  • Understanding of parametric equations
  • Knowledge of trigonometric functions, specifically sine and cosine
  • Familiarity with the Cartesian coordinate system
  • Basic concepts of circle geometry, including radius and center
  • Study the derivation of parametric equations for different geometric shapes
  • Learn about the effects of parameter direction on curve tracing
  • Explore the applications of parametric equations in physics and engineering
  • Investigate the relationship between trigonometric functions and circular motion
Students in mathematics, educators teaching geometry, and anyone interested in understanding parametric equations and their applications in modeling circular motion.
ILoveBaseball
The circle [tex](x-3)^2 + (y-4)^2 = 9[/tex] can be drawn with parametric equations.
Assume the circle is traced clockwise as the parameter increases.
if x = 3+3cos(t) then y= _______?
wouldnt y just be 3+4sin(t)?
Notice the circle is drawn clockwise, your parameter is -t.
Also for your y component, you multiply sin(t) by the radius of the circle. The radius of this circle is 3, not 4. so y = 4+3sin(-t) = 4-3sin(t)
Yes, you are correct. The parametric equations for the circle (x-3)^2 + (y-4)^2 = 9, traced clockwise as the parameter increases, would be:
x = 3+3cos(t)
y = 4+3sin(t)
This is because the center of the circle is at (3,4) and the radius is 3. Therefore, as the parameter t increases, the point (x,y) moves around the circle in a clockwise direction, with x being the horizontal coordinate and y being the vertical coordinate. The equations x = 3+3cos(t) and y = 4+3sin(t) represent the x and y coordinates of the circle at any given point on the circle, as determined by the parameter t.
  • · Replies 16 ·
  • · Replies 29 ·
