What Is a Multilinear Function in Multilinear Algebra?
  • Context: Graduate
  • Thread starter Thread starter BrainHurts
    Algebra Definition
The discussion centers on the definition and properties of multilinear functions in the context of multilinear algebra, particularly as presented in Lee's Introduction to Smooth Manifolds. Participants explore the implications of the definition, provide examples, and clarify the conditions under which a function is considered multilinear.
  • One participant presents a definition of a multilinear function and proposes an alternative formulation, questioning its correctness.
  • Another participant points out that the proposed alternative results in a mismatch in the number of input vectors on each side of the equation.
  • Some participants discuss the specific case of k=2 and clarify how the definition applies, emphasizing the linearity in each variable when others are fixed.
  • A participant provides an example using the inner product to illustrate the concept of multilinearity, expressing confusion about the notation used in Lee's text.
  • There is a suggestion to consider a different formulation of the multilinear function, but it is noted that this would imply linearity, which contradicts the definition of multilinearity.
  • Clarifications are made regarding the linearity of mappings derived from the multilinear function definition, specifically in the case of k=2.
Participants express differing views on the interpretation of the multilinear function definition and its implications. While some clarify and agree on aspects of the definition, others propose alternative formulations that lead to confusion. The discussion remains unresolved regarding the proposed alternative definitions.
Participants express uncertainty about the notation and definitions presented in the source material. There are also unresolved questions about the implications of certain formulations and their adherence to the definition of multilinearity.
BrainHurts
I'm reading Lee's Introduction to Smooth Manifolds and I have a question on the definition of a multilinear function
Suppose [itex]V_{1},...,V_{k}[/itex] and [itex]W[/itex] are vector spaces. A map [itex]F:V_{1} \times ... \times V_{k} \rightarrow W[/itex] is said to be multilinear if it is linear as a function of each variable separately when the others are held fixed: for each i,
[itex]F(v_{1},...,av_{i} + a'v^{'}_{i},...,v_{k}) = aF(v_{1},...,v_{i},...,v_{k}) + a'F(v_{1},..., v^{'}_{i},...,v_{k})[/itex]
I'm thinking that it should look like this,
[itex]F(u_{1},...au_{k} + a'v_{1},...,v_{k}) = aF(u_{1},...,u_{k})+a'F(v_{1},...,v_{k})[/itex]
any comments?
F on the left hand side takes in 2k-1 vectors, and on the right hand side just k.
The definition in the book is correct, do you think it's a typo or are you just throwing out an idea for a different definition?
different idea of course sorry, definitely not trying to correct him, I'm not seeing it as clearly, umm "F on the left hand side." Which F are you talking about? Lee's definition or what I'm thinking it should look like?
OK just wanted to make sure. The F on the left hand side I'm talking about here.
any comments?
Let's suppose k=2. It looks like what you have written is
[tex]F(u_1, a u_2 + a' v_1, v_2) = a F(u_1, u_2) + a' F(v_1, v_2)[/tex]
And F on the left hand side of the equation, and on the right hand side of the equation, have a different number of variables as input
Hmm, honestly I'm still a little confused, I'm trying to think of a more concrete example such as F being an inner product
if we let V=ℝn for example, then V is a vector space over the field ℝ with the usual addition of vectors and scalar multiplication.
so [itex]<\cdot,\cdot> : V \times V \rightarrow ℝ[/itex] given by [itex]\sum_{i=1}^{n} a_{i}b_{i}[/itex] is a multilinear function (namely a bilinear function)
so if we let x,y,z, be in ℝn and let F = <.,.>, then F(ax+by,z) = aF(x,z) + bF(y,z)
= a<x,z> + b<y,z> right?
so using Lee's notation I'm not really seeing it.
or is it better to see it this way?
[itex]F(a(u_{1},...,u_{k}) + b(v_{1},...,v_{k})) = aF(u_{1},...,u_{k}) + bF(v_{1},...,v_{k})[/itex] ?
No, that would imply that ##F## is linear.
In the case k = 2, the definition says that
[tex]F(a v_1 + a' v_1', v_2) = a F(v_1, v_2) + a' F(v_1', v_2)[/tex]
and
[tex]F(v_1, a v_2 + a' v_2') = a F(v_1, v_2) + a' F(v_1, v_2').[/tex]
In other words, the map [itex]V_1 \to W,\;v_1 \mapsto F(v_1, v_2)[/itex] is linear (for fixed [itex]v_2[/itex]), and the map [itex]V_2 \to W,\;v_2 \mapsto F(v_1, v_2)[/itex] is linear (for fixed [itex]v_1[/itex]). This is what it means to be linear as a function of each variable separately.
and
got it! thanks!
  • · Replies 18 ·
  • · Replies 25 ·
