How deep would you have to dig into Mars to reach Earth's gravity?
  • Context: Undergrad
  • Thread starter Thread starter Zaku2
    Gravity Mars
The discussion revolves around the feasibility of creating a colony on Mars that could achieve Earth's gravitational conditions. Participants explore the implications of Mars' lower gravity, the effects of digging into the planet, and the theoretical aspects of gravity as it relates to depth and density.
  • Some participants suggest that living on the surface of Mars, which has 38% of Earth's gravity, could lead to similar medical issues faced in zero gravity environments.
  • Others argue that there is no depth on Mars where gravity would equal that of Earth, citing the shell theorem and the behavior of gravitational acceleration in uniformly dense spherical bodies.
  • A few participants discuss the implications of Mars not being uniformly dense and how that might affect gravitational forces at various depths.
  • One participant proposes a hypothetical scenario involving a frustum-shaped hole dug into Mars, questioning how gravity would behave in such a structure.
  • Another participant emphasizes that gravitational force inside a planet can reach a maximum at certain depths, referencing Earth's core and mantle boundaries as an example.
  • Some participants express uncertainty about the effects of low gravity on human health, questioning whether 0.38g might not be as problematic as assumed.
  • Concerns are raised about the potential risks of human interaction with Martian life, should it exist, and the implications of sending humans to Mars versus establishing habitats in space.
Participants generally disagree on the possibility of achieving Earth's gravity on Mars through digging. While some assert that it is impossible, others explore theoretical scenarios that could challenge this view. The discussion remains unresolved regarding the implications of low gravity on human health and the feasibility of Mars colonization.
Participants acknowledge the limitations of their assumptions, particularly regarding the uniformity of Mars' density and the complexities of gravitational calculations. The discussion also highlights the speculative nature of human health responses to varying gravitational conditions.
Zaku2
I'm a huge space colonization and enterprise enthusiast. one thing i have noticed about most of the Mars habitat plans is they all plan to live on the surface, which is at 38% of Earth's gravity. this would lead to similar if not the same medical problems with astronauts that we already face in zero G. but in space we can create artifical gravity to compensate. I want to know how far down we would have to go to build a colony under the surface at Earth's normal gravity?
Astronomy news on Phys.org
Hello, weclome to PF.
There's no such depth.
The gravitational acceleration of a uniformly dense spherical body falls linearly as you dig down. It'll never be higher than at the surface.(cf.shell theorem)
Planets are obviously not uniformly dense, so that changes things a bit, but you're still stuck with falling gravity, even if not at one to one gravity:distance relationship.
That's true.
No, in the case of Earth gravity is the strongest at the inner mantle/outer core boundary. I don't know the specifics about Mars but the effect is much to weak to get 1 G gravity on Mars.
glappkaeft said:
That's true.
http://en.wikipedia.org/wiki/Shell_theorem
I hope your not saying the shell theorem is incorrect ?
keep in mind the shell theorem is not describing center of mass
edit or rather center of gravity
No, the rate of change of gravity will be largest at the boundary between the two densities but the strength of the gravitational force will decrease as you go down.
Fair enough. that assumes your passing through the mass instead of removing it? what if that 'uniform' mass was not above you to counter-act the change in your distance from the shell? like a 'frustam' shaped hole excavated to the apropriate depth, and wider at the top then the bottom.
@Mordred, HallsofIvy
This is what glappkaeft is referring to:
http://en.wikipedia.org/wiki/File:EarthGravityPREM.jpg
Without doing any calculations, I'd say you'd need to dig down larger part of the surface-centre distance, while removing large part of the planet, and somehow preventing it from rebounding to the hydrostatic equilibrium shape. Unfeasible doesn't begin to describe it.
Ah that makes more sense. I wasn't sure if he was referring to the apparent or effective gravity or not.
Assuming the hole you dig is small compared to the planet, Gauss's law tells us that we don't have to worry about the mass above you. It doesn't matter if you pass through it, or remove it.
Putting words in glappkaeft's mouth, or fingers, he's saying that the shell theorem does not say that gravitational force decreases with increasing depth. He's correct. The shell theorem does not say that. You have to add the assumption of a uniform density to reach that conclusion. He's also correct in that gravitational force inside the Earth reaches a maximum value at the core/mantle boundary. The gravitational force halfway down to the center of the Earth is about 9% higher than the surface value. This is because the Earth's core comprises a bit less than 1/3 of the Earth's total mass but occupies a bit more than 1/6 it's total volume.
What the shell theorem does say is that for an object with a spherical mass distribution (density is a function of radial distance from the center), it's only the mass below that counts. You can use the shell theorem to find the condition that make gravitational force increase or decrease with increasing depth. Defining ##\rho(r)## as the density at some distance ##r## from the center and ##\bar{\rho}(r)## as the average density of all the stuff below that distance, you should find that gravitational force increases with depth if ##\rho(r) < \frac 2 3 \bar{\rho}(r)##.
Yeah I understand now what he was referring to just didn't connect the dots from his post lol.
wow, took me a too little long to wrap my head around all this for my liking :p thanks everyone for your input. guess I'm going to have to come up with a better idea then 'dig a big *** hole' to address the low grav issue. any input??
What low gravity issue? You are assuming that it is an issue, and you are assuming that humans will confront it. Those are both very big ifs. Regarding the former, while zero gravity is known to be problematic to humans, nobody knows where the cutoff is between 0g and 1g that delineates harmful from not harmful. Perhaps there's no big problem with 0.38 g. Perhaps it's even pleasant.
Regarding the latter, that is an even bigger if. We may never send people to Mars. If we have the wherewithal to send humans to Mars long term, we would also be close to having the wherewithal to make a largish space station, one that is hospitable to people. Why would we want to go back down into a gravity well when we just spent an enormous amount of capital to get out of one?
Another downside / risk is Mars life. It's a fairly good bet that Mars did support life of some form long ago. Whether it still does, nobody knows. If it does, there's a potential for harm both ways, Mars life harming us and us harming Mars life. There's a significant faction in NASA (some rather high up) and elsewhere that think that humans must *never* go to Mars if Mars does support life.
D H said:
Regarding the latter, that is an even bigger if. We may never send people to Mars. If we have the wherewithal to send humans to Mars long term, .
There is a dutch company that is asking for volunteers, though its a one way trip. scheduled for 2023.
http://mars-one.com/en/about-mars-one/about-mars-one
posted that as its almost hilarious
there is one statement on that site that relates to the bone loss, in that it may/may not be a problem if your planning on staying there. This company figures the human body can adapt. However it would be a problem coming back to a higher gravity.
The hilarious part is if they go through with this we will have our guinea pigs
The Preliminary Reference Earth Model [compiled from seismic data] estimates the maximum acceleration due to gravity is about 10.66 m/s at the mantle core boundary [approximately .55 Earth radii from the center of earth]. This translates to about an 8.7% increase in gravity at the mantle core boundary compared to the surface. Even assuming Mars has an identical density profile [it does not], it would barely creep over 0.4 Earth gravity at the depth maximum gravity was achieved.
If the need for higher gravity is not full time, for example only during part of pregnancy, building a large centrifuge would cost a lot less than digging a big hole. How big a centrifuge, and at what cost? Various carnival rides, and revolving restaurants on tops of buildings should indicate that cost is pretty low. You could even build in a staircase or elevator to the center if building a large enough constantly rotating centrifuge on Mars.
Even if a couple of hours a day at 1 g was necessary for people returning to Earth, a minimal centrifuge would be light enough to be sent from Earth.
However... There are lots of plans for trips to Mars that haven't kept up with the times. Will we have mature nanotechnology by the time any expedition could leave? Probably, but the degree of nanotechnology and additive manufacturing we have now means that most on planet equipment will be built in situ, perhaps before the (manned) part of the expedition arrives. On the moon, such technology would probably build things from aluminium alloys and glass with bricks thrown in for building construction. But on Mars, iron and steel would be the cheapest building material.
All travel to Mars in the near term is one way - the fastest trip exposes one to 80%+ lifetime radiation exposure limit from cosmic rays. It would take a couple of meters of lead to shield from this on the trip... no such craft can be made like that.
Long term, the success of the human genome project suggests that it may be possible to provide a treatment (a nanotech smart pill, etc.) that rebuilds DNA as it gets damaged, so the shielding would not be necessary.
  • · Replies 17 ·
15K
