Gravitational Potential Energy of a rocket
The discussion revolves around the gravitational potential energy of a rocket launched from the Earth's surface and its speed when it is far away from the Earth. The subject area includes concepts of energy conservation and gravitational potential energy in the context of classical mechanics.
  • Participants discuss the application of the conservation of energy principle, questioning the assumptions made regarding potential energy at different distances. There are attempts to manipulate the energy equations, with some participants pointing out potential errors in algebra and variable definitions.
The discussion is active, with participants providing guidance on checking algebraic manipulations and clarifying the definitions of variables used in the equations. There is no explicit consensus yet, as participants are exploring different interpretations of the energy equations and their implications.
Some participants question the assumption that potential energy becomes zero at a far distance, and there is discussion about the correct application of the radius of the Earth in the equations. The original poster expresses uncertainty about their calculations and potential issues with their calculator.
mcnealymt
A rocket is launched straight up from the Earth's surface at a speed of 1.80×104m/s . What is its speed when it is very far away from the earth? Answer in m/s
K1+U1=K2+U2
.5mV1^2-(G*m*Me)/r= .5mV2^2-(G*m*Me)/r
*** THe mass of the rocket should cancel out and the U1 aka (g*m*Me)/r should be zero.
you are left with:
.5V1^2=.5V2^2-(G*m*Me)/r
*** Now solve for V1
V1 = Square root of [ (.5V1^2+(GMe)/r)/.5 ]
I got 1.06 *10^4
what am I doing wrong? I know that you have to use conservation of energy and assume that since the rocket is traveling a very far distance the final potential energy is going to be zero. Could it be calculator issues?!
Watch the signs, and I think you meant V2 instead of V1 in the square root. I'm assuming that you are letting "1" stand for final and "2" for initial.
Why did you say U1 = 0? It's not.
Then: what is U2?
Your original equation is correct, but your implementation of it is incorrect. The r that goes along with V1 is the radius of the earth, and the r that goes along with V2 is infinite. Also, you need to check over your algebra...you have a problem with those 0.5's.
  • · Replies 43 ·
