Proof about 6k+5 producing an infinite amount of primes
The discussion revolves around proving that the expression 6k+5, where k is an integer, produces an infinite number of prime numbers. Participants explore the implications of this expression in relation to prime number generation and divisibility.
  • Participants discuss the construction of a number Y based on existing primes of the form 6k+5 and question the assumptions regarding its divisibility by other primes. There are debates about whether primes of the form 6k+1 can divide Y and the implications of excluding certain primes from consideration.
The discussion is ongoing, with participants raising questions about the validity of certain assumptions and the structure of the argument. Some have offered insights into the nature of Y and its divisibility, while others express confusion about specific points in the reasoning.
There are mentions of potential gaps in the argument, particularly regarding the treatment of the prime number 5 and the implications of including or excluding certain primes from the set being considered. Participants are careful to note the constraints of their assumptions and the need for clarity in definitions.
cragar
Prove that 6k+5 produces an infinite amount of primes. k is an integer
We first observe that 6k+1,6k+3,6k+5 produce all the odd integers.
Next we see that (6k+1)(6k'+1)=6(6kk'+k+k')+1 so the product of integers of the form
(6k+1)(6k'+1)=6k''+1. And we see that 6k+3 is divisible by 3 so it never produces primes.
when k=1 we see that 6+5=11 and when k=2 we get 12+5=17. so we know that
6k+5 does produce primes. Now let [itex]X= p_1,p_2,...p_n[/itex] be the set of all primes
of the form 6k+5. Now we construct [itex]Y= 6(p_1*p_2*...*p_n)+5[/itex]
Now this new number is bigger than any [itex]p_n[/itex] And let's assume that X is finite. And let's assume 5 is not in X.
But no [itex]p_n[/itex] divides Y so either Y itself is prime or there is a larger prime of the form 6k+5 that divides it. there are an infinite amount of primes of the form 6k+5.
hi cragar! :smile:
why?? :confused:
why can't there be only prime factors of the form 6k + 1 ? :wink:
ok i see what you are saying, [itex]Y=6(p_1*p_2*p_3...p_n)+5[/itex]
my [itex]p_{n's}[/itex] could be primes of the form 6k+1 , but a prime of the form 6k+1 would not divide
Y.
no I'm not :confused:
my [itex]p_{n's}[/itex] could be primes of the form 6k+1 , but a prime of the form 6k+1 would not divide Y.
yes it could :redface:
(perhaps it may help you to rewrite 6k + 5 as 6K - 1 )
tiny-tim said:
yes it could
No, I think you're missing cragar's argument.
Y is clearly not divisible by 2 or 3. If it is also prime to all primes that are 5 mod 6 then it follows that all of its prime factors are 1 mod 6. But cragar has already shown that the primes 1 mod 6 are closed under multiplication, so it must have a factor that is not 1 mod 6.
Where the argument in its current form does break down is that Y is always going to be divisible by 5.
I don't understand why Y is always divisible by 5. I excluded 5 from my [itex]p_n[/itex]
and we need to be careful about numbers of the form (6k+1)(6k'+5)=6(6kk'+5k+k')+5 as tiny tim pointed out.
what I showed is that 6k+5 can't just be composed of factors of the form 6k+1 but it could have factors
(6k+1)(6k'+5). but I still feel that if we include all the primes of the form 6k+1 and 6k'+5 and called those [itex]p_1,p_2...p_n[/itex] and then look at Y no 6k+1 will divide 5. there is still something i am probably missing, thanks for all the help by the way.
Ok, you confused me by writing 'let's assume 5 is not in X', which is clearly false, whereas you meant you were redefining X to exclude 5. But the effect is the same - it creates a hole in the argument.
Why? 6k'+5 would be in X (unless k'=0), and so by construction cannot be a factor of Y. So the only hole in the argument is that Y might be 5 + 6*5*(6k+1)(6k'+1)... = 5*(1+6*(6k+1)(6k'+1)...). OTOH, may be a difficult hole to plug.
I don't think it would be hard to plug if cragar had written ##Y=6(p_1*p_2*p_3...p_n)-1##. That is not divisible by 5. The equivalence class 6k+5 is the same as the equivalence class 6k-1 mod 6. They aren't the same mod 5. I really don't think cragar understands the proof very well.
  • · Replies 16 ·
