Velocity Vector of Object After 4.1 s of Accel.
  • Thread starter Thread starter Robertoalva
    Vectors Velocity
The problem involves determining the velocity vector of an object subjected to acceleration in the y-direction while moving in the x-direction. The object starts with an initial velocity of 1.6 m/s in the x-direction and experiences an acceleration of 0.52 m/s² in the y-direction over a time period of 4.1 seconds.
  • Participants discuss the independence of motion in the x and y directions, with one participant questioning the reasoning behind their calculations for the velocity components. Others provide insights into the application of kinematic equations for each direction.
The discussion is progressing with participants clarifying concepts related to the independence of motion in different directions. Helpful guidance has been provided regarding the application of kinematic equations, and there is an acknowledgment of understanding from the original poster.
Participants are navigating assumptions about initial velocities and the effects of acceleration in separate dimensions. There is an emphasis on understanding the independence of x and y motion in the context of the problem.
Robertoalva
An object is moving in the x direction at 1.6 m/s when it is subjected to an acceleration given by a = 0.52 j m/s2. What is its velocity vector after 4.1 s of acceleration?
v= vxi +vyj
3. The Attempt at a Solution [/b
I got for the i vector 1.6 m/s because it said that that was the x velocity, and for the y velocity I just multiplied the time and the acceleration vector and it gave me 2.13 m/s and both are right but I don't know why, i need someone to explain me why please.
Independence of directions
Remember that the things that happen in the x and y directions are completely independent of each other. Thus the acceleration in the y direction( which is equivalent to applying a force in y direction) only affects whatever is happening in the y direction. The object has velocity in x direction which is given to you but that is not affected by what happens in the y direction. On the other hand in the y direction the initial velocity [itex]v_{oy}[/itex] is zero, so if you apply a constant force ( or introduce constant acceleration) the kinematics equation you are really applying is [itex]v_y=v_{oy} + a_yt[/itex].
Hope this helps
yep. it works because you can think of the equations for x motion as independent of the equations for y motion.
thanks now i know what happens! thanks for the tips also!
