Show exp(A) is invertible for a matrix A
  • Thread starter Thread starter chipotleaway
    Matrix
The discussion revolves around demonstrating the invertibility of the matrix exponential defined as e^A for a matrix A, where A is an n x n matrix satisfying A^{2013} = 0. Participants are tasked with finding an expression for the inverse of e^A in terms of A.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Some participants consider whether demonstrating the invertibility of the function e^x for real numbers can be applied to the matrix case. Others suggest exploring the properties of the matrix exponential through the binomial theorem and its implications for matrices with nilpotent characteristics.
The discussion is ongoing, with participants exploring various approaches to establish the invertibility of e^A. Some guidance has been offered regarding the use of specific properties of matrices, but no consensus has been reached on a definitive method or solution.
Participants are working under the constraint that A is a nilpotent matrix, specifically that A^{2013} = 0, which may influence their reasoning and approaches to the problem.
chipotleaway
Define [itex]e^A=I_n+A+\frac{1}{2!}A^2+\frac{1}{3!}A^3+...+\frac{1}{2012!}A2012[/itex]
where A is an nxn matrix such that [itex]A^{2013}=0[/itex]. Show that [itex]e^A[/itex] is invertible and find an expression for [itex](e^A)^{-1}[/itex] in terms of A.
To first show that it's invertible, can I just show the function [itex]e^x[/itex] has an inverse?
Where x is a real number? That would work fine if A were diagonal. I don't think assuming ##A^{2013}=0## makes it any easier. I would just try to show ##e^{sA}e^{tA}=e^{(s+t)A}## first. It's really just the binomial theorem. Then put s=1 and t=(-1).
Do you know that [itex]x^n- 1= (x- 1)(1+ x+ x^2+ \cdot\cdot\cdot+ x^{n-1})[/itex]?
If not try proving it by induction on n. Notice that proof works for matrices as well as numbers.
Try it first for a matrix B with B^4 = 0 (to make the problem smaller): if you can do it with one where you can see all the terms in the sum and see what happens, writing down the work for your case will just require a little careful writing.
  • · Replies 20 ·
