I don't understand how to laplace transform heaviside functions
The discussion focuses on the Laplace transform of the function (6-t)heaviside(t-2). The user struggles with applying the correct formulas for the Heaviside function, specifically the Laplace transforms: heaviside(t-c) transforms to e^(-c)/s and heaviside(t-c)f(t-c) transforms to e^(-cs)F(s). The user initially misapplies these rules, leading to incorrect results. Ultimately, the correct approach involves rewriting the function in terms of (t-2) and applying the transformation correctly, as outlined in the provided solution.
  • Understanding of Laplace transforms
  • Familiarity with Heaviside functions
  • Basic calculus, particularly integration
  • Knowledge of function shifting in transforms
  • Study the properties of the Heaviside function in Laplace transforms
  • Learn about function shifting techniques in Laplace transforms
  • Practice solving Laplace transforms of piecewise functions
  • Explore advanced applications of Laplace transforms in differential equations
Students studying engineering mathematics, particularly those focusing on differential equations and control systems, as well as educators teaching Laplace transforms and their applications.
1MileCrash
(6-t)heaviside(t-2)
This is just one term of the real problem I'm working, but it will serve to help me figure this out.
http://www.wolframalpha.com/input/?i=laplace+transform+{(6-t)heaviside(t-2)}
I really, REALLY don't understand how to do this, at all.
My textbook makes the following claims:
heaviside(t-c) laplace transform: e^(-c)/s
heaviside(t-c)f(t-c) laplace transform: e^(-cs)F(s) where F denotes the transform of f
Ok, fine. Apparently I am not very math literate because that makes me do the following:
(6-t)heaviside(t-2) = (4-(t-2))heaviside(t-2) = 4heaviside(t-2) - (t-2)heaviside(t-2)
By the rules above, the laplace transform I want to say is:
4e^(-2s)/s - e^(-2s)(1/s^2 - 2/s)
Which is wrong. I have NO idea what to do with this, I don't understand what these rules are telling me to do.
Thanks for any advice.
*sigh* nevermind, I see that I am transforming the shifted function and I shouldn't be.
This is annoying.
1MileCrash said:
(6-t)heaviside(t-2)
4e^(-2s)/s - e^(-2s)(1/s^2 - 2/s)Which is wrong. I have NO idea what to do with this, I don't understand what these rules are telling me to do.
I will use ##u(t)## for heaviside(t). You have the formula$$
\mathcal L(f(t-c)u(t-c) = e^{-sc}\mathcal L(f(t))=e^{-sc}F(s)$$The problem with using this for taking transforms is that usually you are asked to take the transform of ##f(t)u(t-c)##. In your example where ##f(t) = 6 -t## that is why they jump through hoops to write ##6-t =4-(t-2)##, so it is written as a function of ##(t-2)## to match the ##u(t-2)##.
Let's look at what you would get taking the transform of ##f(t)u(t-c)##:$$
\mathcal L(f(t)u(t-c) = \int_0^\infty e^{-st}f(t)u(t-c)\, dt =\int_c^\infty e^{-st}f(t)\, dt$$Now let ##v = t-c## so we get$$
\int_0^\infty e^{-s(v+c)}f(v+c)\, dv =e^{-sc}\int_0^\infty e^{-sv}f(v+c)\, dv =
e^{-sc}\int_0^\infty e^{-st}f(t+c)\, dt=e^{-sc}\mathcal L(f(t+c))$$This says that if you want to transform ##f(t)u(t-c)## you can do the following steps:
1. Replace ##t## by ##t+c## in the formula for ##f(t)##.
2. Transform that.
3. Multiply the result by ##e^{-sc}##.
Try it and see if you like it.
[Edit] I see you solved it while I was typing. Try my suggestion anyway, you might like it better.
