| Thread Closed |
Engine room ventilation system |
Share Thread | Thread Tools |
| Mar30-05, 02:15 PM | #18 |
| Mar30-05, 02:30 PM | #19 |
Mentor
| Mar31-05, 12:16 PM | #20 |
russ-watters, our design is for a security craft.
Since we are allowing the deltaT to go higher( once the engines are turned off it wont take long to blow the air out), we came up with reltively small numbers 12800cfm. |
| Mar31-05, 03:41 PM | #21 |
| Apr8-05, 11:08 AM | #22 |
How to calculate the time required to get the temperature of a room from 140F to 120F?
The case here is (marine), the delta T is 40F while the engines are running once the engines are shutdown, i need to calculate the time needed to bring down the temperature of the room to 120F |
| Apr25-05, 09:08 AM | #23 |
For example, your engines will be hot (they will probably rise well above the 140 degrees F of the air) and giving off heat (until their casing cools). How long will it take to actually cool them? When they first shut off they will give off almost as much heat as when they were firing. This number will decrease until the case is cool, how fast this happens depends largely on the mass of the object, how well it conducts heat and surrounding air temperature. (Did I forget anything physicists?) But the air in the room will cool to 120 deg F in about 1/8 of a minute with 100 deg F incoming air (although the engines, walls, furniture, etc. will still be hot). Sorry it took so long to reply. |
| Apr26-05, 08:43 AM | #24 |
| Apr28-05, 11:38 AM | #25 |
Thanks Artman
| May12-05, 10:59 AM | #26 |
kkkasturi. These are marine diesels? With no water jacket? Air cooled? Generally marine engines are water cooled, in my experience. The ocean makes a really big heat sink and it's convenient too.
| Dec6-07, 02:36 AM | #27 |
if we give large air opening area (for ventilation), how it effect with noise???
thx everybody!!!!! |
| Dec6-07, 01:39 PM | #28 |
Wow, a 2 year old post revived; well done.
Obviously a large opening in the walls of an engine room will allow engine noise to escape. That's why you put attenuators on ventilation louvres. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Engine room ventilation system
| propulsion system for a single engine propeller driven a/c | Mechanical Engineering | 1 | ||
| Ventilation Systems | General Engineering | 1 | ||
| Ventilation effect | General Engineering | 1 | ||
| Question About Ventilation In A Fish | Biology | 1 | ||
