Radius of convergence of power series
The discussion revolves around determining the radius of convergence for a power series defined by coefficients that follow a specific recursive relationship. The original poster presents a series with coefficients defined as \( a_0 = 5 \) and \( a_n = \left(\frac{2n+1}{3n-1}\right)a_{n-1} \) for \( n \geq 1 \). There is confusion regarding the correct radius of convergence, with multiple potential answers suggested.
  • Mixed
  • The original poster attempts to apply the ratio test to find the radius of convergence, leading to a limit involving the coefficients. They express uncertainty about their approach and question the validity of their conclusions.
  • Some participants question the accuracy of the recursive definition used by the original poster and seek clarification on the coefficients.
  • Others suggest that the original poster's calculations may be correct up to a certain point but highlight the importance of recognizing the center of the series.
The discussion is ongoing, with participants providing feedback on the original poster's calculations and clarifying the recursive relationship of the coefficients. There is acknowledgment of the original poster's work being on the right track, but also a recognition of the need to correctly interpret the center of the series for determining the radius of convergence.
There is a noted misunderstanding regarding the coefficients and their implications for the radius of convergence. The original poster has expressed frustration over the complexity of the problem and the feedback received from their teacher.
Alcubierre
The coefficients of the power series [itex]\sum_{n=0}^{∞}[/itex][itex]a_{n}(x-2)^{n}[/itex] satisfy [itex]a_{0} = 5[/itex] and [itex]a_{n} = (\frac{2n+1}{3n-1})a_{n-1}[/itex] for all [itex]n ≥ 1[/itex]. The radius of convergence of the series is:
(a) 0
(b) [itex]\frac{2}{3}[/itex]
(c) [itex]\frac{3}{2}[/itex]
(d) 2
(e) infinite
[itex]lim_{n\rightarrow ∞}|\frac{a_{n+1}(x-2)^{n}}{a_{n}(x-2)^{n}}|[/itex]
[itex]|x-2|lim_{n\rightarrow ∞} |\frac{a_{n+1}}{a_{n}}|[/itex]
To find the function inside the limit, I used the definition presented in the problem:
[itex]a_{n} = (\frac{2n+1}{3n-1})a_{n}[/itex]
Added n + 1 and divided the [itex]a_{n}[/itex] from the RHS which yields,
[itex]\frac{a_{n+1}}{a_{n}} = \frac{2n+3}{3n+2}[/itex]
and substituted that into the limit, and took the limit:
[itex]\frac{2}{3}|x-2| < 1[/itex]
[itex]2|x-2| < 3[/itex]
[itex]2[-(x-2)] < 1\; and\; 2(x-2) < 2[/itex]
And that gives the interval,
[itex]x > \frac{1}{2}\; and\; x < \frac{7}{2}[/itex]
which means the radius is 2, but the correct answer is letter c, [itex]\frac{3}{2}[/itex].
What am I doing wrong? Was my approach in the right direction?
I solved this before and I used the rationale that the radius of convergence is the reciprocal of the limit of the interval, but my teacher said that wasn't correct and it was "one of those special cases that it works out that way."
Alcubierre said:
The coefficients of the power series [itex]\sum_{n=0}^{∞}[/itex][itex]a_{n}(x-2)^{n}[/itex] satisfy [itex]a_{0}[/itex] for all [itex]n\geq 1[/itex].
They satisfy what?!
My apologies.
It should say, it satisfies [itex]a_{0} = 5[/itex] and [itex]a_{n} = \frac{2n+1}{3n-1}[/itex] for all [itex]n ≥ 1[/itex].
Alcubierre said:
My apologies.
That isn't what you used in your solution and it won't give the correct answer. I think you still have something typed wrong.
Sigh, it's been a long day.
OK. Then your work is OK at ##\frac 2 3 |x-2|<1## or ##|x-2|<\frac 3 2##. That says the distance from ##x## to ##2## is less than ##\frac 3 2##. Since ##x=2## is the center of the expansion ##r = \frac 3 2##.
Oh wow I completely disregarded the fact that it's centered at x = 2! Thank you very much
