Enthelpy of an ideal gas and pressure
The discussion centers around the enthalpy of an ideal gas and its dependence on pressure, exploring theoretical implications, mathematical derivations, and interpretations of thermodynamic principles. Participants examine claims made in a Wikipedia article regarding the pressure independence of enthalpy, alongside their own calculations and reasoning.
  • One participant references Wikipedia, stating that the enthalpy of an ideal gas does not depend on pressure, but expresses doubt based on their own mathematical derivation.
  • Another participant corrects a mathematical error regarding the internal energy of an ideal gas, asserting it should be ##U=\frac{3PV}{2}##.
  • Some participants argue that while the enthalpy expression derived includes pressure, it does not account for conditions such as constant temperature, which may lead to different interpretations of pressure dependence.
  • One participant discusses the second law of thermodynamics, suggesting that the enthalpy change with respect to pressure is non-zero, challenging the claim of pressure independence.
  • Another participant states that the Wikipedia claim is inaccurate, asserting that the enthalpy of incompressible solids and liquids does depend on pressure.
  • Some participants express confusion over the implications of enthalpy changes and the types of work involved, questioning why enthalpy changes are restricted to PV work.
  • A participant proposes that the enthalpy of an ideal gas should be expressed as a function of two variables, questioning the assumption that it can depend on three independent variables.
Participants do not reach consensus on the pressure dependence of enthalpy for ideal gases. Multiple competing views are presented, with some arguing for independence under certain conditions, while others assert that pressure does play a role in enthalpy calculations.
Participants highlight limitations in their assumptions and the definitions used, particularly regarding the independence of variables in the context of enthalpy and the conditions under which certain claims hold true.
fluidistic
I've read on Wikipedia that the enthalpy of an ideal gas does not depend on pressure (http://en.wikipedia.org/wiki/Enthalpy:
WikiTheGreat said:
Enthalpies of ideal gases and incompressible solids and liquids do not depend on pressure, unlike entropy and Gibbs energy.
However mathematically I get that it's false. So I'm wondering weather I'm making some error(s) which seems likely or the wiki article is wrong.
Here's my work:
I consider a monoatomic ideal gas.
From the equations of state ##PV=nRT## and ##U=\frac{3nRT}{2}##, one can obtain the fundamental equation ##S(U,V,n)=nS_0+nR \ln \left [ \left ( \frac{U}{U_0} \right ) ^{3/2} \left ( \frac{V}{V_0} \right ) \left ( \frac{n}{n_0} \right ) ^{-5/2} \right ]##. I've done it myself and it can be found in Callen's book.
Now using the definition of the enthalpy, I get that ##H=U+PV## where the independent variables of H are S, P and n. So that ##H(S,P,n)##. In order to get the enthalpy I must get ##U(S,P,n)## and ##V(S,P,n)##.
From the equations of state, I get that ##U=\frac{2PV}{3}##. Plugging that into the enthalpy, I reach that ##H=\frac{5}{3}PV##. So if I can find ##V(S,P,n)## I'm done.
I take the exponential in both sides of the fundamental equation to get ##e^S=\exp \{ nS_0+nR \ln \left [ \left ( \frac{U}{U_0} \right ) ^{3/2} \left ( \frac{V}{V_0} \right ) \left ( \frac{n}{n_0} \right ) ^{-5/2} \right ] \}##
##\Rightarrow e^S = e^{nS_0} \left [ \left ( \frac{U}{U_0} \right ) ^{3/2} \left ( \frac{V}{V_0} \right ) \left ( \frac{n}{n_0} \right ) ^{-5/2} \right ] ^{nR}##
##\Rightarrow \left [ \left ( \frac{U}{U_0} \right ) ^{3/2} \left ( \frac{V}{V_0} \right ) \left ( \frac{n}{n_0} \right ) ^{-5/2} \right ] ^{nR} =e^{S-nS_0}##
##\Rightarrow \left ( \frac{U}{U_0} \right ) ^{3nR/2} \left ( \frac{V}{V_0} \right ) ^{nR} \left ( \frac{n}{n_0} \right ) ^{-5nR/2} =e^{S-S_0n}##
##\Rightarrow \left ( \frac{2PV}{3U_0} \right )^{3nR/2} \left ( \frac{V}{V_0} \right ) ^{nR} n^{-5nR/2} =e^{S-nS_0} ##
##\Rightarrow \left ( \frac{2}{3U_0} \right ) ^{3nR/2} \cdot \frac{1}{V_0 ^{nR}} \cdot n ^{-5nR/2 } \cdot V^{5nR/2} \cdot P ^{3nR/2} =e^{S-nS_0}##
##\Rightarrow V(S,P,n) = e^{\frac{2(S-nS_0)}{5nR}}P^{-3/5}nV_0^{2/5} \left ( \frac{2}{3U_0} \right )^{3/5}##
Which makes [tex]H(S,P,n)= e^{\frac{2(S-nS_0)}{5nR}}P^{2/5}nV_0^{2/5} \left ( \frac{2}{3U_0} \right )^{3/5}= c_1 \cdot e^{c_2(S-nS_0)}P^{2/5}n[/tex] where there's a dependence of the enthalpy on the pressure and ##c_1## and ##c_2## are positive constants.
Science news on Phys.org
This should be ##U=\frac{3PV}{2}##.
True. Also in my last expression for H(S,P,n) I forgot to multiply by that constant. Nevertheless this doesn't change the general expression I reached, namely ##H(S,P,n)=c_1 \cdot e^{c_2(S-nS_0)}P^{2/5}n##. The dependence of H on P remains.
Let me simplify your claim:
claim 0. the enthalpy of an ideal gas doesn't depend on the pressure.
but from the second law dH = TdS + VdP
we have [itex]\frac{\partial H}{\partial P} = V \neq 0[/itex].
All of the extra junk is just working with the integrated forms
of the entropy expression.
Here's a similar line of reasoning for internal energy.
claim 1. the internal energy of an ideal gas doesn't depend on the volume.
but from the second law TdS = dU + pdV
we have [itex]\frac{\partial U}{\partial V} = -p \neq 0[/itex].
So what gives?
The claim isn't about what is the dependence of H on p
when entropy is constant - but when the temperature is held constant.
From your first expressions
[itex]H = U + pV = \frac{3}{2}nR T + nRT = C_p T[/itex],
from whence it's obvious
[tex]\left( \frac{\partial H}{\partial p} \right)_T = 0,[/tex]
and so the enthalpy is independent of the pressure.
So what gives?
Thanks for the reply.
If I understand well the claim of Wikipedia is not really accurate. They should have added "when the temperature is held constant", which isn't a given beforehand. But indeed, if one fixes T, then H doesn't depend on P. I didn't know this, good to know.
Have I understood you well?
Quote by WikiTheGreat
This is incorrect. The enthalpies of incompressible solids and liquids depend on pressure:
[tex]dH = C_pdT+(V-T\frac{\partial V}{\partial T}) dP[/tex]
This is a general thermodynamic relationship the applies to any material.
As I understood it if the pressure changes then the PV work required to establish the system in the environment changes, which is what enthalpy is, according to the first few lines of said wikipedia article. I too thought the claim that enthalpy is not pressure dependent was a bit strange.
Another interesting caveat is found in this document:
http://www.physics.usu.edu/torre/3700_Spring_2015/Lectures/06.pdf
Here we see that for an isobaric H=Q assuming only compressional work is done
However in the following pages conditions are given for dF = W regardless of the type of work.
Any thoughts on why the work done by an enthalpy change is restricted to PV work?
This post makes no sense to me. A key physical characteristic of an ideal gas it that it's enthalpy is independent of pressure. I see absolutedly no reason why one would find it strange the enthalpy is not a function of pressure for an ideal gas.
These lecture notes make no sense to me.
Who says that the work done when enthalpy changes is restricted to PV work?
Hello you all:
first I assume a closed non-reactive system with n=constant, the system being an ideal gas.
lets assume H(U,p,V)=U+pV by definition and let's assume that for an ideal gas, U is a function of T only, hence H=H(T,p,V). However, for an ideal gas pV=nRT, hence of the variables (T,p,V) only 2 are independent, or H is to be expressed as a function of 2 variables. We do not want to drop T, hence we write either H(T,p) or H(T,V).
But when the enthalpy of an ideal gas is not a function of p (as is the issue at hand), then only H(T,V) would be admissible. yes H(T) is also admissible, if H is independent from volume. Is it ??
I would conclude that there is something rotten in the state of enthalpy. The asssumption that it could be a function of 3 independent variables as suggested by the equation in #1 seems unsustainable.
Zeppos10 said:
Hello you all:
Sure.
You have just verified that, per unit mass, U, H, S, A, and G can be expressed as function of any two of the three intensive variables, p, T, and V, where V is the specific volume. This is true of any single-phase substance of constant concentration, not just for an ideal gas. This is because, from the equation of state, any of the intensive variables p, T, or V can be expressed as a function of the other two.
First of all we have for the ideal monatomic gas (easily derivable from the equipartition theorem)
$$U=N k_B T.$$
This is not in the "natural" variables, because due to the 1st and 2nd Law you have
##\mathrm{d} U=T \mathrm{d} S-p \mathrm{d} V.##
So the natural variables for the caloric equation of state in terms of ##U## are ##S## (entropy) and ##V## (volume) rather than ##T##, but of course we can express everything in any two independent thermodynamical variables we like. Further we also know the equation of state
$$p V=N k_B T.$$
To get the entropy (within classical thermodynamics, which is a somewhat difficult issue, because entropy cannot be well defined within classical physics, but you get a good approximation for not too low temperatures). We can only give a relation of entropies with respect to some reference state ##(T_0,V_0)##.
The idea is to use the equation
$$\Delta S=S-S_0=\int_{T_0}^{T} \mathrm{d} T \frac{C_V}{T}+\int_{V_0}^{V} \mathrm{d} V \left (\frac{\partial S}{\partial V} \right)_{T},$$
where we have used a path from the reference state to an arbitrary state in the ##(T,V)## plane by first going from ##T_0## to ##T## keeping ##V## constant and then from ##V_0## to ##V## keeping ##T## constant.
Now we get the heat capacity at constant volume from the 1st Law above as
$$C_V=\frac{\partial U}{\partial T}=\frac{3}{2} N k_B.$$
To get the 2nd integral we need a Maxwell relation. To get the right on we have to consider the free energy
$$F=U-T S.$$
From the 1st+2nd Law we find
$$\mathrm{d} F=-S \mathrm{d} T-p \mathrm{d} V,$$
and since this is a total differential we must have (using the "natural" independent variables, ##F=F(T,V)##
$$\partial_V \partial_T F=-\left (\frac{\partial S}{\partial V} \right)_T=\partial_T \partial_V F=-\left ( \frac{\partial p}{\partial T} \right )_V,$$
i.e., from the EoS
$$\left (\frac{\partial S}{\partial V} \right)_T=\left ( \frac{\partial p}{\partial T} \right )_V=\frac{N k_B}{V}.$$
Plugging this into the integrals for the entropy we get
$$S=N k_B \left [\frac{3}{2} \ln \left (\frac{T}{T_0} \right) + \ln \left (\frac{V}{V_0} \right) \right]=N k_B \ln \left(\frac{V T^{3/2}}{V_0 T_0^{3/2}} \right).$$
Now the denominator in the logarithm can only be a function of the fixed particle number ##N## and from the extensivity of entropy it follows that it must be proportional to ##N##. Thus we find
$$S=N k_B \ln \left (\frac{V T^{3/2}}{\alpha N} \right),$$
where ##\alpha## is a constant.
The natural variables for the entropy are found by using again the 1st+2nd Law:
$$\mathrm{d} S=\frac{1}{T} \mathrm{d} U-\frac{p}{T} \mathrm{d} V.$$
So we should give the entropy as ##S=S(U,V)##. With the caloric EoS we get
$$S=N k_B \ln \left [\left(\frac{2 U}{3 k_B N} \right)^{3/2} \cdot \frac{V}{\alpha N} \right ].$$
Now we can derive all thermodynamical potentials with their natural dependence. You can, e.g., solve the previous equation for ##U=U(S,V)##. Then you have for the enthalpy
$$H=U+p V,$$
for which with the 1st+2nd Law you get
$$\mathrm{d} H = T \mathrm{d} S+V \mathrm{d} p,$$
So you just use the definition of ##H##. Then you just need to express ##V## in terms of ##S## and ##p## to get the natural dependence ##H=H(S,p)##.
Hello All,
I am currently reading Introduction to Chemical Engineering Thermodynamics 7th Edition By Smith, Van Ness, Abbott.
This very subject has come up within my book on pages 126 and 127 for those who have the text.
In the subject of Sensible Heat Effects it outlines for a homogeneous substance of constant composition that internal energy and enthalpy can be expressed as a function of two other state variables.
No phase transitions, chemical reactions and no changes in composition cause the temperature of the system to change.
for U=U(T,V)
dU=(∂U/∂T)VdT + (∂U/∂V)TdV
It says that the final term (∂U/∂V)tdV can be set to 0 under two conditions:
1. Constant volume Process
2. Whenever the internal energy is independent of volume, regardless of process. This is exactly true for ideal gases and incompressible fluids and approx. true for low pressure gases.
The same is said for enthalpy in regards to its second term in the equation
when H=H(T,P)
dH=(∂H/∂T)PdT + (∂H/∂P)TdP
Conditions for being set to zero:
1. Constant pressure
2. Whenever the enthalpy of the substance is independent of pressure, regardless of the process. This is exactly true for ideal gases and incompressible fluids and approx. true for low pressure gases.
After reading this thread I am still confused as to when the enthalpy can be independent of pressure and internal energy can be independent of volume.
If someone could please give me an example in which this would occur I would appreciate the clarification.
From the above posts it seems that enthalpy is dependent on the pressure so I must ask why is this statement found in textbooks?
what about internal energy and volume?
Best Regards,
D
No, enthalpy, also of an ideal gas, can always be expressed as a function of T and p. However, for an ideal gas, H does not change with p, i.e. it is a constant function of p.
HethensEnd25 said:
Hello All,
for U=U(T,V)
when H=H(T,P)
This is not what S and V say. They say:
2. This is exactly true for ideal gases, and approx. true for low-pressure gases, for solids, and for liquids outside of the critical region.
Both sets of statements in S and V are correct. For Enthalpy, the exact relationship is given in S and V (Eqn. 6.20) by:
$$dH=C_pdT+\left[V-T\left(\frac{\partial V}{\partial T}\right)_P\right]dP=C_pdT+V(1-\beta T)dP$$
where ##\beta## is the coefficient of volumetric thermal expansion.
This equation is valid for ideal gases, real gases, liquids, and solids of constant composition and single phase. The second term in parenthesis is exactly equal to zero for an ideal gas (verify it yourself). So, for an ideal gas, H is a function only of T. For liquids and solids, the second term can usually be neglected compared to the ##C_pdT## term; this is because the specific volume of liquids and solids is so very very small. You can satisfy yourself that this is correct by determining what kind of huge change in pressure is required to produce the same change in H as, say, a 5 degree C change in temperature.
In S and V, I could not find the exact equation for dU as a function of dT and dV, but this equation is given by:
$$dU=C_vdT-\left[P-T\left(\frac{\partial P}{\partial T}\right)_V\right]dV$$
This equation is valid for ideal gases, real gases, liquids, and solids of constant composition and single phase. The second term in parenthesis is exactly equal to zero for an ideal gas (verify it yourself). So, for an ideal gas, U is a function only of T. For ideally incompressible liquids and solids, dV=0, so U is a function only of T.
In general, enthalpy is regarded as being dependent on pressure. But, in solving real life problems, don't you think it would be helpful to know under what conditions the pressure dependence of H can be neglected. After all, evaluating that pressure dependent term could involve lots of un-necessary work, and your time is very valuable.
The same goes for the effect of volume (or pressure) on internal energy.
  • · Replies 19 ·
  • · Replies 23 ·
