Charging capacitor by another capacitor
In summary, the process of a charged capacitor discharging while an empty one charges will result in a loss of energy due to the resistance and inductance of the connecting wires. This energy can be dissipated as heat in the resistor or transformed into electromagnetic waves. The rate of charging follows an inverse exponential pattern and the energy lost can be calculated using the formula provided.
bgq
162
Hi,
Consider a charged capacitor connected to a an empty capacitor. The charged capacitor starts to discharge while the empty capacitor starts charging. The whole process finishes when the two capacitors maintain the same potential difference. The problem is that when calculating the energies at the beginning and at the end, we find that they are different. Some books says that the lost energy is dissipated in the connecting wires, yet others say that the energy is transformed into electromagnetic waves.
How can we interpret the loss of the electric energy in this case?
Both types of energy transfer will take place, but which one dominates will depend on the details of the system such as the resistance and inductance of the wires used to join the capacitors.
hi bgq! :smile:
the energy loss equals I2R, so it's certainly the loss through the resistor
from the pf library on capacitor
Inverse exponential rate of charging:
A capacitor does not charge or discharge instantly.
When a steady voltage [itex]V_1[/itex] is first applied, through a circuit of resistance [itex]R[/itex], to a capacitor across which there is already a voltage [itex]V_0[/itex], both the charging current [itex]I[/itex] in the circuit and the voltage difference [itex]V_1\,-\,V[/itex] change exponentially, with a parameter [itex]-1/CR[/itex]:
[tex]I(t) = \frac{V_1\,-\,V_0}{R}\,e^{-\frac{1}{CR}\,t}[/tex]
[tex]V_1\ -\ V(t) = (V_1\,-\,V_0)\,e^{-\frac{1}{CR}\,t}[/tex]
So the current becomes effectively zero, and the voltage across the capacitor becomes effectively [itex]V_1[/itex], after a time proportional to [itex]CR[/itex].
Energy loss:
Energy lost (to heat in the resistor):
[tex]\int\,I^2(t)\,R\,dt\ =\ \frac{1}{2}\,C (V_1\,-\,V_0)^2[/tex]
Thank you very much
I would approach this scenario by first considering the principles of conservation of energy and charge. In this situation, we have two capacitors that are connected in a circuit, and the total charge and energy in the system should remain constant throughout the process. Therefore, any discrepancy in energy calculations should be accounted for by the transfer of energy between the capacitors and the surrounding environment.
One possible explanation for the difference in energy calculations could be the presence of resistive elements in the connecting wires. As the charged capacitor discharges and the empty capacitor charges, there will be a flow of current through the wires, and this current will experience some resistance. This resistance leads to the dissipation of energy in the form of heat, which could account for the discrepancy in energy calculations.
Another explanation could be the emission of electromagnetic waves during the charging and discharging process. As the charges move back and forth between the two capacitors, they can create electromagnetic waves that carry energy away from the system. This energy loss would also need to be taken into account when calculating the final energy of the system.
Ultimately, the exact cause of the energy loss in this scenario may depend on the specific parameters of the capacitors and the circuit. It is important to carefully consider all potential factors, such as resistive elements and electromagnetic waves, in order to accurately interpret the loss of electric energy in this case.
What is "charging capacitor by another capacitor?"
"Charging capacitor by another capacitor" refers to a method of transferring electrical energy from one capacitor to another. This process involves connecting the two capacitors in a circuit and allowing the charge to flow from one capacitor to the other until they reach equal voltages.
How does charging capacitor by another capacitor work?
When two capacitors are connected in a circuit, the capacitor with the higher voltage will discharge its energy to the capacitor with the lower voltage. This causes an equalization of voltage between the two capacitors, with the total energy being divided between them.
What are the benefits of charging capacitor by another capacitor?
Charging capacitor by another capacitor allows for the efficient transfer of electrical energy from one capacitor to another without the use of any additional components. This method can also help to stabilize voltage levels and improve the overall performance of a circuit.
Can any type of capacitor be used for charging capacitor by another capacitor?
Yes, any type of capacitor can be used for this process as long as they are compatible and have similar voltage ratings. However, it is important to consider the capacitance values and ensure that the capacitors are able to handle the amount of energy being transferred.
Are there any safety concerns when charging capacitor by another capacitor?
Yes, there are some safety concerns to be aware of when using this method. Capacitors can store a significant amount of electrical energy, so it is important to handle them with caution and discharge them properly before attempting to connect them in a circuit. Additionally, make sure to use capacitors with appropriate voltage ratings to avoid any potential hazards.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
12K
  • Electromagnetism
  • Electromagnetism
