Probability of Random Walk and Reaching a Destination with Equal Probabilities
The problem involves a random walk scenario where a person takes steps forward and backward with equal probabilities. The specific questions focus on calculating the probability of ending up at a certain position after a set number of steps and the likelihood of reaching a destination within a limited number of steps.
  • Participants discuss the use of binomial distribution to calculate probabilities for the random walk, with some questioning the correctness of their interpretations and calculations. There is a focus on the number of forward and backward steps needed to achieve the desired position.
There is an ongoing exploration of the problem with various interpretations being discussed. Some participants have offered alternative perspectives on how to approach the calculations, particularly regarding the conditions for stopping the walk and the implications of reaching the destination.
Participants are grappling with the implications of the random walk's stopping conditions and the need to account for different scenarios in their calculations. There are references to recursive techniques for determining probabilities, indicating a complexity in the second part of the problem.
marina87
Statement:
A drunk person wonders aimlessly along a path by going forward 1 step and backward 1 step with equal probabilities of ½. After 10 steps,
a) what is the probability that he has moved 2 steps forward?
b) What is the probability that he will make it to his front door within 20 steps before he collapses with the door being 6 steps in front of him.
My approach was to use Binomial in both cases:
a)10C2 (0.5)^10
b)20C6 (0.5)^20
Is that correct? I have been reading about random walk and they sometimes give another equation.
(10+2)/2=6 and thn the result is like this 10C6.
The result is not the same and then I start to have my doubts.
Can some one please tell me if my approach using binomial distribution is right?
Can you explain how you got a and b? a) looks like you tried to calculate the probability that out of the 10 steps he took, 2 of them were forward steps, which would result in being 8 steps backwards from his starting position
I used combinations and yes that's what I tried and how I saw it at the beginning. The probability of try 10 times and only success two times but then I had my doubts. I am not sure if I am approaching the problem in the correct form because he can move two steps backyards and then he is going to move 4 steps forward.
That's not how I read the problem. He has to end up 2 steps forward from his starting position after taking 10 steps, which means he needs 6 forward steps and 4 backwards steps (which will get you a 10C6 in the solution)As an aside, for your interpretation you do have to divide by an additional 2 to eliminate that problem
marina87 said:
Statement:
a)10C2 (0.5)^10
b)20C6 (0.5)^20
In (a), if he takes f steps forward and b steps backward, you need f-b=2 and f+b=10. With the correct f and b, the binomial will apply.
In (b) you need to account for the fact that if he reaches the front door the walk stops; that is, the walk stops when he reaches the front door or takes 20 steps, whichever comes first. Therefore, a simple binomial will not apply.
So I don't have the correct combination. Its not 10C2 its 10C6. That is what I obtain using
N=#steps
X=#steps forward
y=(N+X)/2 --> 10Cy I use the Y in the combinatorial.
@RAY I understood the first part (a) but I have breaking my head with the second part. I have been thinking in how to do this but everutime that I think that after 6 steps forward or reach position 6+ I can not get forward I stop.
That makes sense and it fix find but I am at zero can I go to position -1? I want to understand/interpret correctly the problem.
One way to get the probability is through a recursive technique. Let f(i,m) = probability of eventually reaching the door, given the man is in state i and has m possible steps left; here, "state" refers to position, so in state i he is i steps from the door. The answer you want is f(6,20). Now look at what happens in one step: from state i he goes to state i+1 or state i-1, each with probability 1/2. Thus, f(i,m) = (1/2)*f(i+1,m-1) + (1/2)*f(i-1,m-1) for i > 1. For i = 1 we have f(1,m) = (1/2) + (1/2)*f(2,m-1).
Starting from f(1,1) = 1/2, and f(i,1)=0 for i >= 2 we can get f(i,m) for all i and all m <= 20. Note that we do not need to have large values of i, since the total number of steps allowed is <= 20. In fact, the maximum number B of backward steps is given by B + 6 + B = 20, or B = 7. That means we do not need i larger than 6+B = 6+7 = 13. In other words, i <= 13 throughout.
You can fairly easily program the recursion in a spreadsheet, starting from the initial values f(1,1) = 1/2, f(i,1) = 0 for 2 <= i <= 13.
  • · Replies 18 ·
