Net Power In a Charged Rotating Cylinder
The problem involves a long hollow nonconducting cylinder with a uniform surface charge, which is subjected to an external torque causing it to rotate with a constant angular acceleration. The task is to determine the net power entering the cylinder from surrounding electromagnetic fields at a specific angular velocity.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the relationship between electromagnetic waves and the rotating charged cylinder, with some suggesting the use of the Poynting vector to analyze power flow. Others question the relevance of the electromagnetic wave equation in this context.
Several participants are exploring different interpretations of the problem, including the application of magnetic fields and energy density concepts. Some guidance has been offered regarding the use of the Poynting vector and the relationship between changing magnetic and electric fields, but no consensus has been reached on the method to be used.
Participants note the potential complexity of the problem, with references to the need for understanding electromagnetic wave generation due to accelerating charges. There is also mention of the course level, indicating it is a general physics course.
Erubus
A long hollow nonconducting cylinder (radius R= 0.060 m, length L= 0.70 m) carries a uniform charge per unit area of σ= 4.0 C/m^2 on its surface. Beginning from rest, an externally applied torque causes the cylinder to rotate at constant acceleration α= 40 rad/s^2
about the cylinder axis. Find the net power entering the interior volume of the cylinder from the surrounding electromagnetic fields at the instant the angular velocity reaches ω= 200 rad/s.
(Answer 4.6μW)
I=S[itex]_{avg}[/itex]=[itex]\frac{1}{cμ_{0}}[/itex] * [(E[itex]_{max}[/itex])[itex]^{2}[/itex]*sin[itex]^{2}[/itex](kx-ωt)]
The intensity I of the electromagnetic wave is [itex]\frac{Power}{Area}[/itex] where I assumed the area would be the surface area of the cylinder (2[itex]\pi[/itex]*r*L).
so to find the net power through the cylinder I thought it would just be I*area.
From a previous chapter, I determined that E=[itex]\frac{σ}{2ε_{0}}[/itex].
With angular acceleration α=40rad/s^2 the cylinder would reach the angular velocity
ω= 200rad/s^2 in t=5 seconds.
I'm not sure if this is the right approach to the problem. I don't know what to do about x or the angular wave number k in the intensity function.
Not sure why you're invoking the planar moving e-m wave equation.
I would think of this as a solenoid once the cylinder is spinning.
You can imagine N turns in L = 0.7 meter with each turn carrying q/N coulombs with q = 2πRLσ total coulombs.
Then, as the cylinder spins, the charges represent current in each "winding" and you can solve for B inside the solenoid.
Once you have B you of course have the total magnetic field energy within the cylinder.
I'm sorry, can you explain a bit further? I used the e-m wave equation because that is the topic of the section in which this question was asked. How would I use the total magnetic field to find the power?
Energy density = B2/2μ0
Energy = energy density * volume
Funny that the question arose in conjunction with e-m waves. Maybe I'm looking at it the wrong way ...
I guess since these are accelerating charges there will be an electromagnetic wave generated. A bit beyond me I'm afraid. Is this an advanced e-m course?
EDIT: oh, and it asks for power entering the cylinder. Doing it my way that would be dE/dt where E = Energy. That would account for the need for an accelerating cylinder, so that dE/dt is not zero.
It's a general physics course. Thanks for the replies, I will keep working on it.
Maybe this is a problem on the application of the Poynting vector. As the cylinder spins, a B field is set up inside as rude man o:) said. Since the rate of spin is increasing, B is increasing. The increasing B field will induce an E field. If you can find the E field at the surface of the cylinder, you can construct the Poynting vector and determine the rate of flow of field energy into the interior region of the cylinder.
I think it wants the rate of increase in energy within the cylinder. Increasing angular velocity increases the B field and changing B field creates E field. Thus we have to calculate the total energy U (due to B and E fields) as a function of time and then dU/dt will the power.
Yes, that should give the same result as integrating the Poynting vector over the surface of the cylinder. Since the question asks for the "net power entering the interior volume of the cylinder from the surrounding electromagnetic fields", it made me think of the Poynting vector as the appropriate method. But the question is not really very clear on the method to be used.
So maybe del x E = -∂B/∂t in addititon to d/dt B2/2μ0?
Then E field energy = |E|2/2ε0
and E power = d/dt of above ...
Since B is increasing linearly with time, E will be constant. So, the E-field energy will not be changing with time and there will be no power going into the E field energy at the instant of time of interest.
EDIT: But del x E = -∂B/∂t is relevant for finding the E field at the surface of the cylinder in order to construct the Poynting vector. You can show that the integral of the Poynting vector over the surface of the cylinder is equal to the rate of change of the total B-field energy inside the cylinder which is also equal to the mechanical input power of whoever/whatever is turning the cylinder.
EDIT 2: In the last sentence I should have said equal to the mechanical input power done against the electrical force acting on the charged surface of the cylinder by the induced E field. There is also additional mechanical input power necessary to increase the rotational kinetic energy of the cylinder due to its mass.
  • · Replies 29 ·
