Why are electrons located so far from an atom's nucleus?
  • Context: High School
  • Thread starter Thread starter mia5
    Electron Orbit
The discussion revolves around the question of why electrons are located at significant distances from an atom's nucleus. Participants explore various perspectives, including classical analogies, quantum mechanics, and the relative sizes of atomic components.
  • Some participants reference Ernst Rutherford's analogy of electrons orbiting the nucleus like planets around the sun, suggesting a balance between attractive and centrifugal forces.
  • One participant questions the definition of "so far away," arguing that a few Angstroms may not be considered far in relative terms.
  • Another participant counters that the distance from the nucleus to the electron is approximately 10^5 times the size of the nucleus, which could be interpreted as 'far away'.
  • Some argue that the perception of distance could be subjective, suggesting that the nucleus might be considered too small rather than the electron being too far away.
  • Participants discuss the implications of quantum mechanics, noting that the wave nature of electrons establishes a minimum likely distance for their position, represented by probability density functions.
  • One participant mentions that the light mass of the electron and the weak electromagnetic interaction contribute to larger expectation values for the distance from the nucleus.
Participants express differing views on the concept of distance in atomic structure, with no consensus on whether electrons are "far away" from the nucleus. The discussion includes subjective interpretations and varying explanations based on classical and quantum perspectives.
Limitations in the discussion include the subjective nature of distance perception, dependence on definitions of "far away," and the unresolved complexities of quantum mechanics in relation to atomic structure.
mia5
Why are the electrons so far away from the nucleus of an atom ?
One time Ernst Rutherford said that that the rotation of electrons around the nucleus like the rotation of the planets around the sun , so the attraction force that made the planets rotate around the sun but wasn't enough to make these planets stick to the sun due to the centrifugal force . The same in the atom , there is an equality between the attractive force and the centrifugal force ( because the nucleus is positive and the electrons are negative )
What do you consider to be "so far away"? I'd say that a few Angstroms as not be far away at all!
Zz.
Zz.
The distance from the nucleus to the electron ( in this basic picture of atoms !) is about 10^5 times the size of the nucleus. Would you not call this 'far away' relatively speaking?
Nope, because:
1. I could consider that it is the nucleus that is too small, rather than the electron being too far away,
2. The electron actually DOES get quite close to the nucleus. Look at the spread in position for the 1s orbital, for example.
Zz.
Is the Earth far away from the Sun because the Sun is 'too small'?
The sun isn't far away. Its by far the closest star to the Earth there is. Its so close that it appears as a disk rather than a point in the sky. :-p
You obviously miss the whole point of my question to the OP and my reply to you. A question that is simply based on "is it too far away" is subjective! I illustrated that by countering that it could be too small. Who is to say which is "correct"? This then renders the question simply a matter of personal taste, rather than based on physics.
I noticed to neglected the second part of my response, which actually HAS a physics content.
Zz.
OP could be speaking relatively.If someone enlarges an atom to the size of the earth, the electron should be much far away than the moon
The reason for the spacings inside an atom are based on Quantum Mechanics, I think. The wave nature of the bound electron gives a minimum likely distance for it to be found 'in orbit' (the probability density function).
The electron is light (as in: not heavy) relative to the nucleons, and the electromagnetic interaction is weak. Both effects lead to large expectation values for the distance, and both have no known deeper reason.
yeah. It is (loosely speaking) because the electromagnetic coupling constant is much smaller than the coupling constant of the strong force. Also, as mfb said, the mass of the electron is smaller than the mass of the nucleons.
  • · Replies 19 ·
  • · Replies 20 ·
  • · Replies 55 ·
  • · Replies 50 ·
37K
