Water Does Not Leak Back To The Other Side.
  • Thread starter Thread starter Dug Fmjamul
    Water
The discussion revolves around the behavior of water in a partitioned aquarium setup, specifically addressing why water flows from the 7-gallon side to the 3-gallon side until levels equalize, but does not flow back when the 7-gallon side is drained. Participants explore the implications of pressure differences and the effectiveness of the seal between the two sides.
  • Some participants suggest that the seal may not have been applied properly, leading to a situation where it acts like a valve.
  • Others propose that the water pressure on the 7-gallon side is greater than on the 3-gallon side, which could explain the initial flow of water.
  • There are questions about whether the seal can close once water has leaked from the 7-gallon side to the 3-gallon side.
  • Some participants express surprise that water continues to leak until both sides are level.
  • There is a discussion about the relationship between water height and pressure, with some participants asserting that only height matters for pressure, while others seem to imply that volume plays a role.
  • One participant raises the possibility of small stones or obstacles affecting the flow between the two sides.
Participants do not reach a consensus on the reasons behind the observed behavior of water in the aquarium. There are competing views regarding the role of pressure, the effectiveness of the seal, and the influence of physical obstacles.
Discussions include assumptions about the pressure exerted by water based on height versus volume, and the effectiveness of seals under different conditions. Some participants express confusion over the implications of pressure differences in this context.
Dug Fmjamul
I sealed with silicone and partitioned a 10 Gallon Aquarium with an 8 inch by 8 inch double glass plate with about 3 gallons on one side and 7 gallons on the other. The 3 gallon side was to be dry and filled with gravel and rocks, while the 7 gallon side would have a thin bottom layer of gravel and filled with water. After some time the water links over to the 3 gallon side until it is level with the water on the 7 gallon side. But when I drain the 7 gallon side of water the 3 gallon side does not leak over to the 7 gallon side and the water level does not drop.
Any clues as to the 'why'? Because I don't have any and I'm baffled why the water doesn't leak back over to the 7 gallon side.
You didn't seal it properly
and the poor seal you did do is acting like a valve
Dave
Welcome to the PF. Can you upload a picture of the setup? How did you brace the partition?
To expand on previous posts, the water pressure is higher on the 7 gallon side than the 3 gallon side. Your seal may be good enough to handle the pressure on the 3 gallon side, but not good enough to handle the pressure on the 7 gallon side.
That said, I'm surprised the water would continue to leak until both sides were level.
Once initially broken in the direction from the 7 gallon side to the 3 gallon side, they fail to close up again as long as there is any water between the seal and the wall?
While in the opposite scenario, water on the 3 gallon side and none on the 7 gallon side, the pressure from the 3 gallon side acts to close the seals that were initially broken?
I know that.
Dave
That makes sense, but a one-way valve?
Thanks, that sounds plausible. But if I gradually add water to the 7 gallon side would there be a point where the 3 Gallon side would start to release water to the 7 gallon side? I'm going to try that and see what happens.
It is possible that there may be some small stones or obstacles near where the leak happens but only on one side. So this would allow allow water to flow more easily from one side to the other.
I don't really support the caging of fish or animals/birds. They have the same right to freedom as we do.
Similar to the valves in your heart.
Or the PCV in your car, a foot valve at the bottom of the pipe in a well, ...
How do you figure there is a pressure difference from one side to the other?
Because one side is empty and the other is full?
Or are you asking why 7 gallons of water exerts more pressure on the divider than 3 gallons will when one side is full and the other is empty?
As straight forward as the question should seem to be, I'm pretty sure I don't really understand what you're asking.
Bob, you aren't suggesting volume has anything to do with pressure, are you? The only thing that matters is the height of the water. (I got the same impression from reading your first post as well.)
Yes russ, I read that post the same way you do.
i think it can be assumed that with one side full and the other empty the full side exerts more pressure than the empty side.
after all the questioner does state
Since after the water equalizes in height of both sides, there had to be more pressure on the 7 gallon side than the 3 gallon side.
i don't see any reference to pressure being a result of volume.
I DO see a reference to it and I want to know if I am missing something because I think it is pretty common knowledge that the height of the water is what determines the pressure. Obviously the 7 gallon side will have more pressure than the 3 gallon side when the 3 gallon side is lower than the 7 gallon side. But it seemed to me that it was implied that the 3 gallon side does not develop the same pressure in reverse when the 7 gallon side is lower than the 3 gallon side.
This is the statement in question:
So what is it? Did I miss something?
the 7 gallons side leaks to the 3 gallon side ( originally empty) until both are of the same height. Then the 7 gallon side is drained and water does not leak from the 3 gallon side to the 7 gallon side. The original height h of the 7 gallon side would have to have been greater than the starting h of the 3 gallon side. That is how I interpreted the original scenario and carried that along from post to post.
It is cumbersome to be calling the containers the 7 gallon side and 3 gallon side.
I am not saying my interpretation is any more correct than yours - just that I did not notice any problem with the statements. You and Russ did. Now I tend to wonder by polling readers what the percentage of readers would see it either way. I cringe at the possibility of being a lonely minority of 1.
Other than Bob coming in with his explanation.
Ok 256. I was just wondering if I misunderstood the setup. Yes it is a cumbersome description.
Pressure isn't solely straight down (or you wouldn't need the divider at all). Surely the lateral pressure on the glass (which would actually cause the leaking) would be greater the greater the amount of mass the glass divider is holding back. I'm not actually sure, since that's something that seems so obvious that I really haven't thought about it that much.
Edit: Or, the total amount of mass doesn't matter. That seems very counter-intuitive. Obviously, it couldn't be a straight linear relationship, since inserting a hollow tube into the ocean would be holding back the entire ocean, but I'm surprised it doesn't seem to matter at all (at least in a few minutes of browsing).
It may be instructive to try and understand why there should be a sideways force in the first place. For eg., if you try to stack a pile of bricks on the floor one on top of the other they would be in stable equilibrium and not require any sideways force. Now if we try to stack a column of water on the floor, its not going to stay that way. Its going to spill. Now let's try the same thing with marbles. It is theoretically possible to stack the marbles with all their centres in a straight vertical line so that they would be in unstable equilibrium and not require a sideways force to keep them in equilibrium. But in practice for the majority of the number of ways in which the stacking can take place this would not be the case. For any two marbles whose centers are not aligned in the same vertical line there would be a sideways force. If you look at a marble which is in the interior, on an average the horizontal forces from all directions would cancel out. But if you look at one at the side, there would be a net outward horizontal force. This horizontal force would only depend on the weight of the marbles on top of it plus the force transmitted downwards (and sideways) by the ones above those. So it appears that it will depend only on the height and not on the total number of marbles.
Anyways this is just a rough example we don't know how water behaves at the molecular level (at least I don't!) but in practice we find that the pressure depends only on the height(depth) [itex]p = p_0 + \rho gh[/itex] so it appears that water behaves more similarly to marbles than bricks!
  • · Replies 74 ·
  • · Replies 23 ·
23K
  • · Replies 19 ·
11K
  • · Replies 42 ·
  • · Replies 17 ·
  • · Replies 23 ·
