Thread Closed
Banked curve involving friction
Share Thread Thread Tools
Apr1-05, 11:37 PM   #1
Hi could some of you guys please help me with question, its question 77 in Understand Physics By Cummings.
For those that don't have access to the book its a question dealing with a banked curve with radius R and a angle alpha. Now there is also a friction force stoping the car from sliding of the banked curve, now my question is how do you derive the equation to explain the situation. I know for a normal banked curve without friction the answer is just, Nsin(angle) = m(v^2)/r and Ncos(angle) = mg
So therefore tan(angle) = (v^2)/rg
Now how do you derive the equation is friction is also a force helping the car sliding down, i know the answer is suppose to be vmax = (rgtan(angle + tan^-1(co-efficient of f)))
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Apr2-05, 05:54 AM   #2
If the speed of the car is any greater than the speed you calculated without friction, then the car will need an additional friction force to keep it moving in a circle. This force is parallel to and pointing down the slope. You can decompose this force into its horizontal and vertical components. The horizontal component adds to the component of normal force in the horizontal direction, and the vertical component adds to the force of gravity.
Apr2-05, 06:37 PM   #3
Quote by jdstokes
Done this, but what i get is this relation:
(Vmax)² = Rg(sinx + (co-eff)cosx)/(cosx - (co-eff)sinx)
Where co-eff = co-efficient of friction for the particular surface. How do i change this equation into the answer which is:
(Vmax)² = Rg(tan(x + arctan(co-eff)))
Apr2-05, 10:47 PM   #4
Back to the question, i was wondering if you can use the identity
tanx = co-effcient of friction
Its just that friction is acting down the plane for this circumstance...if you can then i know that arctan(co-eff) will just be the the angle of the bank. That way it could simplify down to tan2x but this doesn't yield the same answer as tan(x + arctan(co-eff)). Any suggestions guys?
Apr2-05, 11:15 PM   #5
I don't think the statement [latex]\tan x = \mu[/latex] is true. Your equation [latex]gr\left(\frac{\sin x + \mu\cos x}{\cos x - \mu\sin x}\right)[/latex] is mathematically equivalent to [latex]gr\tan\left(x+\tan^{-1}\mu \right)[/latex].
Apr3-05, 03:28 AM   #6
Quote by jdstokes
I don't think the statement [latex]\tan x = \mu[/latex] is true. Your equation [latex]gr\left(\frac{\sin x + \mu\cos x}{\cos x - \mu\sin x}\right)[/latex] is mathematically equivalent to [latex]gr\tan\left(x+\tan^{-1}\mu \right)[/latex]. I'm not sure how to get it into this form, however.
Yes i know that the 2 equations are mathematically equivalent but how do i go from one form to the other? I was thinking [latex]\tan x = \mu[/latex] also because other wise the expression could be simplified to [latex]gr\tan\left(2x\right)[/latex]
Apr3-05, 03:51 AM   #7
You begin with
[latex]gr\left(\frac{\sin x + \mu\cos x}{\cos x - \mu\sin x}\right)[/latex].
Divide the numerator and the denominator by [latex]\cos x[/latex]
[latex]gr\left(\frac{\tan x + \mu}{1 - \mu\tan x}\right)[/latex].
Using the identity
[latex]\tan\left(\alpha + \beta\right) = \frac{\tan\alpha + \tan\beta}{1 - \tan\alpha\tan\beta}[/latex]
you get [latex]\alpha = x[/latex] and [latex]\tan\beta = \mu \Rightarrow \beta = \tan^{-1}\mu[/latex]. The result is
[latex]gr\left(\frac{\sin x + \mu\cos x}{\cos x - \mu\sin x}\right) \equiv gr\tan\left(x + \tan^{-1}\mu \right)[/latex].
Apr3-05, 03:59 AM   #8
Homework Helper 2012
Recognitions:
Homework Helper Homework Help
Quote by SeReNiTy
[tex]\frac{\sin(x) + \mu\cos(x)}{\cos(x) - \mu\sin(x)}=\frac{tan(x) + \mu}{1-\mu \tan(x)}[/tex]
You know the addition law for the tangent function:
[tex] \tan(x+y) = \frac{\tan(x) + \tan(y)}{1-\tan(x) \tan(y)}[/tex]
Let
[tex] y = \arctan(\mu) \rightarrow \mu = \tan(\arctan(\mu)) [/tex]
Replace for mu in your formula and you get the desired form.
ehild
Apr3-05, 04:55 AM   #9
Recognitions:
Quote by SeReNiTy
The friction makes it a little more difficult.
The horizontal forces are:
(1)[tex]F_{xfriction} = \mu_sF_Ncos\theta[/tex]
(2)[tex]F_{Nx} = F_Nsin\theta[/tex]
Therefore:
(3)[tex]F_Nsin\theta + \mu_sF_Ncos\theta = mv^2/r[/tex]
One has to look at the vertical components of the forces to find the normal force. These have to sum to zero (since there is no vertical acceleration). The friction force has a downward vertical component and this, together with gravity, equals the vertical component of the normal force:
[tex]mg + \mu_sF_Nsin\theta = F_Ncos\theta[/tex]
So:
(4)[tex]F_N = mg/(cos\theta - \mu_ssin\theta)[/tex]
So substituting into (3):
[tex]\frac{mg}{(cos\theta - \mu_ssin\theta)}(sin\theta + \mu_scos\theta) = mv^2/r[/tex]
(5)[tex]v = \sqrt{\frac{rg(sin\theta + \mu_scos\theta)}{(cos\theta - \mu_ssin\theta)}[/tex]
AM
Apr3-05, 06:27 AM   #10
Thanks to all for helping out, especially to ehlid and Jd for providing the proof for the trig identity.
Thread Closed
Thread Tools
Similar Threads for: Banked curve involving friction
Thread Forum Replies
Banked curve with friction Introductory Physics Homework 19
Friction on a Banked Curve Introductory Physics Homework 3
Friction less Banked curve General Physics 3
Banked Curve , w/ friction Introductory Physics Homework 7
