Register to reply
Hole in the Bucket Problem
Share this thread:
HelpMePleez
#1
Jun10-13, 09:11 PM
P: 4
This was a problem on a test today, and it is driving me nuts that I cannot figure it out. We were told that we had a bucket 1 meter off of the ground with a 3.5 mm hole in the bottom. The water sprayed a horizontal stream 60 cm from the bucket. We are asked to find the
2. Relevant equations
I know we need to use bernoulli's just not sure how.
3. The attempt at a solution
I tried to solve for velocity and height.. but it seems like you need one to get the other.
Phys.Org News Partner Science news on Phys.org
Mysterious source of ozone-depleting chemical baffles NASA
Water leads to chemical that gunks up biofuels production
How lizards regenerate their tails: Researchers discover genetic 'recipe'
gneill
#2
Jun10-13, 10:24 PM
Mentor
P: 11,675
Quote Quote by HelpMePleez View Post
Find the... ???
haruspex
#3
Jun11-13, 01:28 AM
Homework
Sci Advisor
HW Helper
Thanks
P: 9,791
How long will the water take to hit the ground? If it lands 60cm away, how fast is it moving horizontally?
HelpMePleez
#4
Jun11-13, 08:50 AM
P: 4
Oh sorry asked to find the height of the water in the bucket
gneill
#5
Jun11-13, 09:12 AM
Mentor
P: 11,675
Start with haruspex's advice. If you consider the water stream to be composed of a series of discrete slugs of water, each behaving like a free-falling projectile, can you determine the initial horizontal velocity one such slug must have in order to land 60cm away?
After that you can worry about how deep the water in the bucket has to be to produce this velocity (as you surmised, Bernoulli is involved).
HelpMePleez
#6
Jun11-13, 11:37 AM
P: 4
I cannot seem to find a way to find the time it takes to hit the ground, when all I know is distance in the y and x direction. Is acceleration g? and if so does that mean it's zero in the x?
gneill
#7
Jun11-13, 11:42 AM
Mentor
P: 11,675
Yes, the water is falling under the influence of gravity. So how long does it take something to fall 1m from rest?
HelpMePleez
#8
Jun11-13, 12:01 PM
P: 4
I found the right equation. Solved for t in the y direction and then used that to find initial v in the x direction, then used bernoulli's to find height! Thanks you guys very much for the help!
Register to reply
Related Discussions
HELP! Investigating the rate of discharge of water from a hole in a bucket General Physics 6
Water Bucket problem Introductory Physics Homework 3
Rate of flow from a bucket with a hole in it. Precalculus Mathematics Homework 3
Tension/bucket problem Introductory Physics Homework 2
Falling Bucket problem Introductory Physics Homework 5
