Converting data to a specified range
  • Context: Undergrad
  • Thread starter Thread starter Ronni
    Data Range
This discussion focuses on converting a dataset ranging from -50000 to 26214400 into a specified range of 0 to 10. The user breaks down the data into four distinct intervals: 50000-1048576 maps to 0-2.5, 1048577-5242880 to 2.6-5, 5242881-15728640 to 5.1-7.5, and 15728641-26214400 to 7.6-10. The proposed method involves first normalizing the data to a range of 0 to 1 by subtracting 50000 and dividing by 26164400, followed by scaling to the desired range by multiplying by 10. The user notes that while the overall conversion is valid, the resulting intervals are irregular.
  • Understanding of data normalization techniques
  • Familiarity with mathematical scaling methods
  • Basic knowledge of interval mapping
  • Experience with numerical data manipulation
  • Research advanced normalization techniques for irregular intervals
  • Learn about piecewise linear functions for data transformation
  • Explore tools for data visualization to analyze transformed data
  • Investigate statistical methods for handling outliers in datasets
Data analysts, statisticians, and anyone involved in data preprocessing or transformation tasks will benefit from this discussion.
Ronni
Hi,
I am trying to convert data to a particular range of 0-10.
Actual Data may vary from - 50000 - 26214400. I have broken this down into 4 parts as follows -
Code:
50000 - 1048576 -----> 0 - 2.5
1048577 - 5242880 -----> 2.6 - 5
5242881 - 15728640 ----->5.1 - 7.5
15728641 - 26214400 ----->7.6 - 10
How can i convert this data ? Is there any formula to do this? I found a way to normalize data to a range of [ 0 - 1 ] but am not able to apply the same to this.
Your numbers range from 50000 to 26214400? (I'm no certain if that is a dash or a negative in front of the "5000".
First subtract 50000 from each of your numbers to get them between 0 and 26214400- 50000= 26164400.
If you now divide each of your numbers by 26164400 they will be between 0 and 1. Is that what you say you can do? To get them between 0 and 10, now multiply by 10 which is the same as having divided by 2616440 instead of 26164400.
That is a dash.
This converting of whole data to a range of 0-10 is ok but the intervals are irregular that's why i divided the data into the mentioned intervals.
  • · Replies 0 ·
  • · Replies 96 ·
14K
