Vertical or Horizontal ellipse?
The discussion revolves around identifying the orientation of an ellipse derived from a conic equation. Participants are analyzing the standard form of the ellipse and its characteristics, including the center, axes lengths, and foci.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants explore the relationship between the denominators in the standard form to determine the ellipse's orientation. Questions arise regarding the implications of the center's coordinates and the calculations for the foci.
Some participants have provided insights into the characteristics of the ellipse, while others are questioning the calculations related to the foci and the relationship between the axes lengths. There is an ongoing exploration of the implications of the values derived from the standard form.
Participants mention potential mistakes in calculations and the need for clarification on the definitions of the axes and foci. There is also a reference to graphing as a method to visualize the ellipse's properties.
aisha
[tex]16x^2+9y^2+192y-36y+468=0[/tex]
Was the original conic i had to conver this into standard form and got
[tex]\frac {(x+6)^2} {9} + \frac {(y-2)^2} {16} =1[/tex]
Im not sure if this is a horizontal or vertical ellipse
the center of the ellipse is [itex](-6, 2)[/itex]. If you get [itex]x=-6[/itex], then what range of values can [itex]y[/itex] take? If you set [itex]y = 2[/itex] then what range of values can [itex]x[/itex] take?
Can these facts help you to decide? If you can't see why they can directly, then draw a picture of the ellipse and see if you can tell~
since the denominator of the x is less that the denominator of the y then the equation is in the form
[tex]\frac {(x-h)^2} {b^2} + \frac {(y-h)^2} {a^2}[/tex]
I think if what I said is right then this is a vertical ellipse
a=4 b=3?
indeed it is.
Here are the features i got for this conic
Vertical ellipse
Center (-6,2) a=4 b=3
Length of major axis 2a=8
Length of minor axis 2b=6
Vertices (-6,-2) and (-6,6)
Foci=(-6,-3) and (-6,7) where c=5
are all of these correct?
:smile:
The focus is outsie of the ellipse? What is wrong? Is this ok?
(h,-c+k) and (h,c+k) are the foci because this is a vertical ellipse
c=5 and I plugged in the center (-6,2) wats wrong?
what's [itex]c[/itex], and why do you think it's [itex]5[/itex]?
If you're using it that way, then it should be [itex]\sqrt{7}[/itex] (I made a mistake earlier, by the way... that's why the other post is gone now :wink:)
c= sqrt(a^2+b^2) how is it sqrt7?
it's actually
[tex]b^2 = a^2 - c^2 \Longrightarrow c^2 = a^2 - b^2 \Longrightarrow c = \sqrt{a^2-b^2}[/tex]
using your formula, you would always find the focii outside the ellipse.
Thanks soo much I made the same mistake in 3 problems now I rememeber thankssssssss LIFE SAVER! :smile:
If the value under y^2 is greater, then it's going to be a vertical ellipse.
If the value under x^2 is greater, then it's going to be horizontal.
You can check by graphing and calculating the lengths of the major and minor axes. That should help you too.
  • · Replies 17 ·
  • · Replies 38 ·
  • · Replies 21 ·
  • · Replies 18 ·
