Friction Forces, find the coefficient of kinetic friction
The problem involves determining the coefficient of kinetic friction for a crate being pushed across the floor at a constant velocity. The scenario includes a force applied at an angle, which adds complexity to the analysis of forces acting on the crate.
  • Participants discuss the application of Newton's Second Law in both the x and y directions. There is mention of drawing a free body diagram to visualize the forces involved. Questions arise regarding the significance of the angle at which the force is applied.
Some participants have offered guidance on starting with a free body diagram and considering the sum of forces. There is an ongoing exploration of how to relate the friction force to the applied forces, but no consensus or resolution has been reached yet.
The problem setup includes specific values such as the mass of the crate and the applied force, but there may be uncertainties regarding how to incorporate the angle of the applied force into the calculations.
bellanella23
Hello,
I am stuck on this question, I don't understand what to do. Any help would be great! I know that I have to use Newton's Second Law in the x and y directions.
Greezy is pushing a very large crate of 50 kg across the floor at a constant velocity with a force of 200N. He is pushing on the crate upwards at an angle of 20 degrees.
What is the coefficient of kinetic friction between the ground and the create?
I don't understand what to do with that angle that is upwards?
Thanks again!
bellanella23 said:
Hello,
Thanks again!
On problems like this, you should usually start by drawing a free body diagram (FBD), showing the forces on the object. Then what do you do with the sum of the forces in each dimension (hint: F=ma)...?
Thank you.
You're solving for mu_k.
In order to do that you should know what Friction Force is equal to. Plug that in and solve!
  • · Replies 16 ·
  • · Replies 20 ·
