Dynamics Physics - Acceleration Analysis / Gear Ratios /
In summary, Gears A and B, with masses of 4kg and 10kg respectively, are rotating about their mass centers. The radius of gyration for A is 100mm and for B is 300mm. A constant couple of 0.75Nm is applied to gear A. Neglecting friction, the angular acceleration of gear A is 18.75 rad/s^2 and the angular acceleration of gear B is 2.5 rad/s^2. The tangential contact force between the gears at point C is 5N. The motion of one gear affects the motion of the other due to the coupling of the masses.
f2434427@rmqkr
First time posting.
Gears A and B, of Masses 4kg and 10kg, respectively, are rotating about their mass centers. The radius of gyration about the axis of rotation is 100mm for A and 300mm for B. A constant couple of C=0.75Nm acts on gear A. Neglecting friction, compute:
- Angular Acceleration of each gear
- Tangential contact force between the gears at CMay want to look at attachment for image.
Started with the smaller gear.
Using T=I[itex]\alpha[/itex] , where I=mr^2
Rearrange the equation to get [itex]\alpha[/itex] = 0.75 / (4*0.1^2) = 18.75 rad/s^2
Not to sure how to draw a relationship with the 2nd larger gear. Maybe using w1/w2 = r2/r1 then [itex]\alpha[/itex] = w^2 * r
Thanks,
Welcome to PF;
The applied torque has to accelerate both gears doesn't it?
If this were a linear case, you'd use a free body diagram to couple the masses wouldn't you?
Ah yes, that would make sense. Forgot to account for the 2nd gears inertia
hmm. Dont quite understand what you mean by coupling the masses though
When you push on one mass, it pushes on the other one .. the masses are said to be coupled ... the motion of one affects the motion of another.
Alrighty,
Well the force applied from gear A, will have an opposite reaction on Gear B.
T=F*d
F=0.75/0.15 = 5n
then applying this force to Gear B.
T=F*D = 5 * 0.45 = 2.25 Nm
alpha = T/I = 2.25/(10*0.3^2) =2.5 rad/s^2Looks about right to me... hopefully. Logically, first gear would have to spin faster than the 2nd.
That's right - the smaller gear will reach a higher angular velocity in the same time, so must have a higher acceleration. You should be able to see from the relative sizes how the accelerations are related.
1. What is acceleration in physics?
Acceleration in physics is defined as the rate of change of an object's velocity over time. It can be calculated by dividing the change in velocity by the change in time.
2. How does gear ratio affect acceleration?
Gear ratio refers to the ratio between the number of teeth on two gears that are meshed together. In a vehicle, a higher gear ratio means that the engine will have to turn more to make the wheels turn, resulting in a slower acceleration. Conversely, a lower gear ratio will result in a faster acceleration.
3. What is the formula for calculating gear ratio?
The formula for calculating gear ratio is gear ratio = number of teeth on input gear / number of teeth on output gear. This can also be expressed as the number of rotations of the input gear to make one rotation of the output gear.
4. How do you analyze acceleration in dynamics physics?
To analyze acceleration in dynamics physics, you need to first calculate the net force acting on an object using Newton's second law (F=ma). Then, you can use this net force, along with the object's mass, to calculate its acceleration. This analysis can also involve considering the object's velocity and position over time.
5. How do gear ratios affect the speed of a vehicle?
Gear ratios can affect the speed of a vehicle in two ways. First, a higher gear ratio will result in a lower top speed, but the vehicle will be able to reach that speed more quickly. Second, a lower gear ratio will result in a higher top speed, but the vehicle will take longer to reach that speed.
  • Classical Physics
  • Mechanical Engineering
