Find the mutual inductance between the coil and the wire in two ways
The problem involves finding the mutual inductance between a toroidal coil and an infinite wire positioned along its symmetry axis. The original poster outlines two methods for determining this mutual inductance: one by analyzing the induced voltage in the coil when a current flows through the wire, and the other by examining the induced voltage in the wire when a current flows through the coil.
  • Exploratory, Assumption checking
  • The original poster attempts to solve the first method by considering the magnetic field generated by the wire and its effect on the coil. However, they express confusion regarding the second method, questioning how to find the magnetic flux on the wire if it is outside the coil. Some participants raise concerns about the completeness of the toroidal coil and the implications of having a gap in the wiring, suggesting that this could affect the magnetic field experienced by the wire.
The discussion is ongoing, with participants exploring different interpretations of the problem. Some have offered insights regarding the magnetic field behavior in real-world scenarios, while others have proposed alternative approaches to conceptualizing the problem. There is no explicit consensus yet, but the dialogue appears to be productive.
Participants are considering the implications of an incomplete toroidal coil and the assumptions regarding magnetic fields in and around solenoids. The original poster's confusion about the magnetic flux and its relation to the wire indicates a need for clarification on these assumptions.
sapz
We have a toroidal coil, and an infinite wire that runs through it on its symmetry axis. (See picture)
We need to find the mutual inductance between the coil and the wire in two ways:
1. By running a current through the wire, and finding the induced voltage in the toroidal coil.
2. By running a current through the toroidal coil, and finding the induced voltage in the wire
So, I manage when trying to solve (1): If there's a current in the wire, there's a magnetic field in the Theta direction, through the coil, and we can find L.
However, if I try to solve it through (2): If I run a current through the coil, then the magnetic field would exist only inside the coil! So how can I find the flux on the wire, if it's outside the coil?... It would just be zero all the time, wouldn't it?
Any help would be appreciated!
I'm not sure if this is part of the problem, but it appears to me that the toroidal solenoid is not complete - that is, there's a gap in the wiring. If this is truly part of the problem, then there would be a field which "comes out" of the gap and thus a field on the wire.
If the picture is just misleading and the toroid is supposed to be complete, then my only offering is that saying there is no magnetic field outside the solenoid is not technically correct. That is only the case in an ideal system (in the same world where all cows are spherical). In the real world there will be a field outside of the solenoid, albeit it will be very small and decay rapidly.
I don't have an answer to your problem but hopefully those points might be insightful enough for you.
Ive got it! You take the infinite wire, and close it in infinity.
That way you have a closed loop that the flux through it is the flux through the toroid, and therefore there's a current and we can get L.
The magnetic field that the toroidal coil creates is identical to the magnetic field that one finds around a wire with current in it. Can one exists without the other?
  • · Replies 0 ·
