Does the strength of an electric field in a wire change with shape?
The strength of an electric field in a wire does not inherently change with the shape of the wire, such as when it is formed into a spiral. The electric field strength is influenced by the proximity of charges rather than the configuration of the wire. For example, when a long charged wire is coiled into a compact shape, the electric field in the vicinity may increase due to the closer arrangement of charges, but this effect is not a direct result of the spiral shape itself.
  • Understanding of electric fields and charge distribution
  • Familiarity with basic electrostatics principles
  • Knowledge of wire configurations and their effects on electric fields
  • Concept of proximity effects in charged objects
  • Research the mathematical formulation of electric fields around charged wires
  • Explore the effects of charge density on electric field strength
  • Learn about the principles of electrostatics in different geometries
  • Investigate the implications of charge distribution in practical applications, such as capacitors
Physics students, electrical engineers, and anyone interested in the principles of electrostatics and electric field behavior in various wire configurations.
pghazanfari
If I have a charged wire and shape it into a spiral, is the electric field stronger?
Maybe at some points, maybe weaker at some points.
Sometimes its helpful to consider extreme cases. If I have a very long charged wire that extends for miles, then I spiral it up into a small package the field near by should be stronger, right? But that doesn't really depend on the fact that its spiraled, only that the charges are now closer together.
What is your line of thinking here?
  • · Replies 22 ·
  • · Replies 41 ·
