Credit card Magnetic strip and the plastic bag trick
The discussion revolves around the phenomenon of using a plastic bag to enhance the scanning of a worn credit card magnetic strip at grocery checkouts. Participants explore the mechanics behind this method and its implications for card wear and scanner technology.
  • One participant expresses confusion about why a plastic bag helps scan a worn magnetic strip, seeking explanations.
  • Another participant suggests that the issue lies with the card itself rather than the scanner.
  • A third participant references an external source that discusses the enhancement effect of a plastic bag on magnetic strips.
  • Some participants agree that wear on credit cards is a common issue that many experience.
  • One participant proposes that the plastic bag acts as a low pass filter, reducing noise and sidebands caused by scratches on the card, but questions why scanners do not have this capability inherently.
  • Another participant speculates that newer scanners might perform better in this regard and suggests that the problem could persist with increasingly scratched cards over time.
Participants generally agree that worn cards can cause scanning issues, but there are multiple competing views regarding the effectiveness and necessity of the plastic bag method, as well as the capabilities of scanners.
Some assumptions about the mechanics of magnetic strip reading and the effects of wear on cards remain unresolved. The discussion does not clarify the specific technical reasons behind the effectiveness of the plastic bag.
Rolliet
When my credit card magnetic strip is worn it won't scan at the grocery check out. The clerk then uses a plastic bag over the card and runs it through the scanner. I'm baffled why this should work, but it does every time. Any explanations ?
Thanks
This is a fault of your card rather than their scanner?
Yes, a problem when a card gets old. I'd think it happens to everyone.
The separation by the bag must be, effectively, a low pass filter - reducing noise and 'sidebands', due to the scratches (modulation of the basic stripe frequencies). It can't be more than that. I don't know why the scanner couldn't do this for itself, in a more efficient and adaptive way. Maybe the newer generation scanners work better. It would need a 2D array of sensors to do best.
sophiecentaur said:
... I don't know why the scanner couldn't do this for itself, in a more efficient and adaptive way. ...
I think you would still come to the same situation, but with a card more scratched up, after a time.
Hopefully, the card would be out of date by that time. :wink:
14K
14K
12K
