| Thread Closed |
Try to find out what this is : |
Share Thread | Thread Tools |
| Apr3-05, 07:18 AM | #1 |
Take a sheet of paper, a straightliner and a compass.
Make a cylinder out of the sheet of paper and use the compass to draw on the cylinder a "circle" with the same radius as the cylinder (let's put that radius R=1(whichever unit you want)). Unfold the sheet and take the big axis of the closed curved obtained. One can show, this length is : [tex] L=\frac{\pi}{3} [/tex]. Triple this distance with compass, and you can now construct a square which perimeter is [tex]4\pi[/tex] Now construct a circle of radius 2, and you built a circle of same perimeter as the square above.... |
| Apr3-05, 10:26 AM | #2 |
wait how do you draw a circle on a cylinder? do you mean to go all the way around? because that would give you only [tex] 2 \pi r [/tex] i dont see where the [tex]\pi/3[/tex] comes from...
*edit* maybe you mean to draw it on sideways, and even then, why would you want a square with the same perimeter as a circle? forgive the naiveness of my questions (also, exactly how do you draw a circle on sideways like that if you dont want to crush your paper cylinder?)
| Apr3-05, 01:17 PM | #3 |
Well the point is exactly that taking the compass (carefully) on the cylinder doesn't draw a circle (neither an ellipse by the way).
If you want : look at the cylinder from the basis circle : take the radius of the cylinder on your compass : put (carefully), the compass on the surface of the cylinder. You immediatly see that this does not make the complete turn around of the cylinder, but only 60°=Pi/3.....Is that clearer ? Since you now unfold the paper, u get a length that is multiple of Pi u did the quadrature of the circle. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Try to find out what this is :
| [SOLVED] how to find Fa.....to find other unknowns...? | Introductory Physics Homework | 13 | ||
| Find f(x)... | General Math | 5 | ||
| Once i find the radius of convergence, how do i find the interval of convergence? | Calculus & Beyond Homework | 3 | ||
| Need help trying to find something! | Mechanical Engineering | 3 | ||
| Find f(x) | Introductory Physics Homework | 8 | ||
