vertical cord tension in an elevator
by Robertoalva
Tags: acceleration, elevator, tension
Robertoalva
Robertoalva is offline
#1
Jun20-13, 08:55 AM
P: 140
1. An elevator starts from rest with a constant upward acceleration and moves 1 m in the first 1.4 s. A passenger in the elevator is holding a 4.8 kg bundle at the end of a vertical cord. What is the tension in the cord as the elevator accelerates? The acceleration of gravity is 9.8 m/s^2.
2. Relevant equations
F=ma
3. The attempt at a solution
I did a body diagram and get to the conclusion that T=mg-a. to get the acceleration i first had to get the velocity in the first 1.4s. v=d/t= 1m/1.4s=.714m/s and then get the a=v/t=(.714m/s)/1.4s=.510m/s^2
please correct me if i'm wrong
Phys.Org News Partner Science news on Phys.org
Cougars' diverse diet helped them survive the Pleistocene mass extinction
Cyber risks can cause disruption on scale of 2008 crisis, study says
Mantis shrimp stronger than airplanes
voko
voko is offline
#2
Jun20-13, 09:03 AM
Thanks
P: 5,529
According your conclusion, the faster the acceleration upward, the lighter the bundle seems to the passenger. Does that look right to you?
Robertoalva
#3
Jun20-13, 09:05 AM
P: 140
so i have to add the acceleration?
voko
voko is offline
#4
Jun20-13, 09:09 AM
Thanks
P: 5,529
No, you do not 'have' to. But you should use Newton's second law, which you have already written down: F = ma.
You know m, and know a. What is F?
dreamLord
dreamLord is offline
#5
Jun20-13, 09:11 AM
P: 199
Voko is taking care of the other part, so I'll just say that your procedure of calculating the acceleration of the elevator is incorrect. What you have done is found out the average velocity by dividing total distance upon total time, and then further average acceleration.
Use one of the kinematic equations which connect distance, acceleration and time.
Robertoalva
#6
Jun20-13, 09:11 AM
P: 140
F=ma= (.51m/s^2)(4.8kg)= 4.448 N
Robertoalva
#7
Jun20-13, 09:18 AM
P: 140
so, for getting the acceleration I use x= xi+vit+(1/2)at^2 and because i know that vi=0 and xi=0 then x=1/2at^2 ? and the v=d/t?
voko
voko is offline
#8
Jun20-13, 09:19 AM
Thanks
P: 5,529
Quote Quote by Robertoalva View Post
How does that help you find tension?
F is the sum of all the forces. What forces are there?
Robertoalva
#9
Jun20-13, 09:28 AM
P: 140
a downward force F=mg and the upward force being F=ma, and the tension would be F=mg? right ? because that's the force applied downwards
dreamLord
#10
Jun20-13, 10:04 AM
P: 199
Why do you need the velocity? The formula will give you the acceleration of the elevator.
voko
voko is offline
#11
Jun20-13, 10:09 AM
Thanks
P: 5,529
From the bundle's point of view, what forces are acting on it?
Please do not use one symbol for many different things.
Robertoalva
#12
Jun20-13, 10:50 AM
P: 140
Fb=mg which is the downward force acting on the bundle a.k.a. the cord and F=ma which is the upward force acting by the elevator going up
voko
voko is offline
#13
Jun20-13, 10:53 AM
Thanks
P: 5,529
The bundle has no contact with the elevator. It cannot be acted upon by the elevator.
Robertoalva
#14
Jun20-13, 11:01 AM
P: 140
but obviously there has to be 2 forces acting on the bundle, and i know for sure that one of those has to be "mg"
voko
voko is offline
#15
Jun20-13, 11:06 AM
Thanks
P: 5,529
That is correct. But what is the other force? What, except gravity, acts on the bundle?
Robertoalva
#16
Jun20-13, 11:07 AM
P: 140
the tension of the rope? xD i always had difficulties with this kind of problems
Robertoalva
#17
Jun20-13, 11:16 AM
P: 140
I think I understand now. The tension is one force acting on the bundle, and gravity is another right?
voko
voko is offline
#18
Jun20-13, 11:16 AM
Thanks
P: 5,529
Yes.
Register to reply
Related Discussions
Tension in cord. Introductory Physics Homework 9
Cord tension & how to calculate force magnitude of a cord & pulley Introductory Physics Homework 7
Tension on a moving cord (Elevator) Introductory Physics Homework 9
Tension of a cord Introductory Physics Homework 0
Tension in the cord??? Introductory Physics Homework 22
