Restore sgn(f(x)), f(x)=abs(sinc(x)) ?
by blighme
Tags: idft, ltspice, sinc
blighme
blighme is offline
#1
Jun20-13, 10:51 AM
P: 12
Hello
I don't know if this is the right place to place this, but here it goes:
I tried an IDFT approach in LTspice, which doesn't know sqrt(-1). If z=a+i*b then, in LTspice, z=a, |z|=a, so b is lost. With this in mind, the IDFT is done with sin^2+cos^2 which gives me |sinc(x)|, but I need the sinc to be "regular" sinc, oscillating. So, the question is: is it possible through whatever trick/cheat/etc to restore or get an oscillating sinc(x) after the transform? Anything.
I am using this chain of .funcs:
real(n,t)=sin(2*pi*n*(t-M/2)/(M+1))*f(n)
imag(n,t)=cos(...)
re(t)=real(0,t)+real(1,t)+...
im(t)= ...
h(t)=hypot(re(t),im(t))/(M+1)
Anticipated thanks,
Vlad
PS: No homework,their time is long past. This is to try and implement a simple IDFT in LTspice.
Phys.Org News Partner Engineering news on Phys.org
Lifting the brakes on fuel efficiency
PsiKick's batteryless sensors poised for coming 'Internet of things'
Researcher launches successful tech start-up to help the blind
blighme
blighme is offline
#2
Jun21-13, 11:39 AM
P: 12
Unfortunately, I was in a hurry to fight a headache last night, so I mixed up: real(n,t)=cos(...), imag=sin. Also, the resulting impulse response can't be a result of a simulation, for example, I can't just use u(sinc-1m) and then divide the pulses with a DFLOP -- that would require simulating to find out the coefficients, then applying them to h[n], then running the simulation again.
A small test for if(abs(x)<wc,1,0) reveals it works, but it's still |sinc| (by the way, the title is actually sgn(abs(f(x))), f(x)=sinc(x), it was a really bad headache, apparently). To actually test the coefficients, I could use sgn(sinc(wc))*result, but that would only work for rectangular spectrum or one band only.
So, there you have it, if anyone knows just a little bit, please let me know.
Vlad
blighme
blighme is offline
#3
Jul6-13, 11:59 AM
P: 12
No need anymore, the discrete cosine/sine transforms do the trick.
Register to reply
Related Discussions
Integral sinc(a sin theta) knowing sinc, sinc^2 etc. Calculus & Beyond Homework 9
Window Lost want to restore Computers 9
complete system restore Computers 2
Please restore my sanity General Math 16
Restore Image from T40 to R52 Computing & Technology 2
