Find Integer Solutions Problem
  • Context: Undergrad
  • Thread starter Thread starter Andromeda321
    Integer
The discussion revolves around finding all ordered pairs that are integer solutions to the equation xy/(x+y) = 4. Participants explore various methods to approach the problem, including algebraic manipulation and factorization.
  • Homework-related
  • One participant suggests solving for x in terms of y or vice versa to identify integer values.
  • Another participant expresses difficulty in isolating x or y completely, noting that the rearrangement does not simplify the problem.
  • A different participant reformulates the equation to xy = 4x + 4y and critiques the idea of searching for solutions without a mathematical approach.
  • One participant derives x = 4y/(y-4) and questions for which values of y this expression yields an integer.
  • Another participant proposes a transformation of the equation to facilitate finding integer solutions, suggesting that only factors of 16 greater than 4 should be considered.
  • A participant shares their realization of having found nine integer solutions and mentions computing limits to confirm the absence of additional solutions outside a specified range.
  • One participant introduces an alternative method by equating xy/(x+y) to 4n/n and suggests solving simultaneous equations with n as a variable.
Participants express varying methods and approaches to the problem, with no consensus on a single solution or method. Multiple competing views remain regarding the best way to find integer solutions.
Some participants' approaches depend on specific assumptions about the values of x and y, and there are unresolved steps in the mathematical reasoning presented.
Andromeda321
Hey everyone,
I came across this problem recently and I'm trying to find an answer for it to satisfy my curiosity (that and it's easy to understand but hard to actually solve, so tantalizing!). Can anyone give me a nudge in the right direction?
Find all ordered paris that are integer solutions to the following equation:
xy/ (x+y)= 4
Thanks!
Mathematics news on Phys.org
Solving for x in terms of y, or y in terms of x will help. Then find what integer values for one will make the other an integer.
I tried that but couldn't get one completely separated from the other. For example when you solve for x you get 4(x+y)/y which doesn't really help you much.
You can write this as [tex]xy = 4x + 4y[/tex] , but I don't believe you can simply "look" for the solution. That is entirely unmathematical.
Alright, so [tex]\frac{xy}{x+y}=4[/tex] which means [tex]xy=4(x+y)=4x+4y[/tex]
[tex]xy-4x=4y[/tex]
[tex]x(y-4)=4y[/tex]
[tex]x=\frac{4y}{y-4}[/tex]
For what values of y is 4y divisible by y-4?
it would be easier to put it in this form, then do it...
y-4=C 4(C+4)/C C>4
(4C+4)/C= 4+(16/C) so now we figure that 16/C . so the only values is the factors of 16 excluding all those less than 4. this is a big hint.
*smacks head* Ok, got it now! Nine values all told, and then I computed limits to show that there were no other values it could possibly be before (-12, 3) and after (20, 5). Thanks guys! :biggrin:
i feel u should equate xy/[x+y]as 4n/nwhich is still the samenow in this caseu might take xy 2 be 4n and x+y as n .then solve the simul eqn.n being any number,just give it a try
31K
  • · Replies 16 ·
