Register to reply
Want to know what is the best in terms of friction
by victor2006
Tags: friction, terms
Share this thread:
victor2006
#1
Jun27-13, 03:39 PM
P: 6
i want to use a 100 cm diameter piston witch will have 4000 kg of pressure on it.
Questions
-how thick does the piston have to be to hold that much weight if it is made of metal?
-what material should i use to make a seal to the cylinder wall and should the cylinder wall be another material then metal?
-what is the static friction on the cylinder wall and seal if lubricated?
thank you for your time
Phys.Org News Partner Physics news on Phys.org
Engineers develop new sensor to detect tiny individual nanoparticles
Tiny particles have big potential in debate over nuclear proliferation
Ray tracing and beyond
mfb
#2
Jun27-13, 04:46 PM
Mentor
P: 11,925
4000kg is not a pressure, it is a mass.
Which metal?
Without any special requirements, steel is probably a good choice for the cylinder wall. The next question: which type of steel.
Hard to tell without more details about the setup.
fedaykin
#3
Jun27-13, 05:31 PM
P: 124
http://en.wikipedia.org/wiki/Frictio...ts_of_friction has some static friction coefficient values for lubricated steel on steel. I would not trust these values for any serious work though.
The coefficient of static friction gives you an approximation of static friction as a portion of the normal force. The normal force is basically how hard your surfaces are pressing against each other.
victor2006
#4
Jun29-13, 10:42 AM
P: 6
What i want to do is have a cylinder that is made of steel (don't know what types there are but i guess regular)
with a height of 20 ft or so, filled with water. for the bottom of the cylinder i want a piston that would move 6 inches.
the volume of the water on top of the piston is about 4000 liters
i was wandering if you could tell me how thick the steel would have to be so that it would support that weight.
Register to reply
Related Discussions
Are all quadratic terms in gauge fields necessarily mass terms? Quantum Physics 0
Charge density in terms of (r,θ) but need it in terms of the vector r' Advanced Physics Homework 8
Kinetic friction in terms of velocity Introductory Physics Homework 6
Find the acceleration in terms of friction Introductory Physics Homework 1
Friction in molecular terms Introductory Physics Homework 0
