Register to reply
Constructibility of a Perfect Venn Diagram
Share this thread:
CarsonAdams
#1
Jun28-13, 11:13 PM
P: 15
Is it possible using only a straight edge and a compass to construct a Venn Diagram or a pair of overlapping circles in which the area of the lune of each circle is equal to the other and to the area of the overlapping region?
(I've worked out most of the mathematics from calculating the area of the sector (cad) and subtracting the area of the triangle (cad) to achieve the segment of the circle created by the chord (cd) which accounts for half the total overlap. Then to achieve a useful equation, I calculated that, obviously, the area of the circle divided in half must equal twice the area of the single segment created by the chord.)
After simplifying, it would seem that to construct the required angle θ the equation
θ-sin(θ)=π/2
would have to be solved (in radians), which would seem to denote that it is not a constructible angle.
But questions of constructibility usually require someone much more clever than I, so am I missing a simplifying way to achieve this? and is it fair to say that the only way to solve the above equation is through the use of numerical methods?
*if it would be useful to review the full calculation, I can post that as well- it's just a bit tedious
Phys.Org News Partner Mathematics news on Phys.org
Heat distributions help researchers to understand curved space
Professor quantifies how 'one thing leads to another'
Team announces construction of a formal computer-verified proof of the Kepler conjecture
Simon Bridge
#2
Jun29-13, 06:17 AM
Homework
Sci Advisor
HW Helper
Thanks
Simon Bridge's Avatar
P: 12,962
To construct the diagram so all three areas are equal - you need to construct a base-line, then bisect it - the circles, of equal fixed radius (1 unit), are to intersect on that line so their centers are on the base-line. So the problem is to relate the location of the centers of the circles to the areas.
The area of the intersection region is twice the area of the circular segment cut off by the bisecting line.
Using the diagram in wikipedia: the distance from the bisector to each center is ##d##.
... I don't know if this can be constructed.... but it would amount to how finely you could divide lengths up.
Register to reply
Related Discussions
My Venn diagram General Discussion 19
Venn diagram Precalculus Mathematics Homework 3
Venn Diagram Precalculus Mathematics Homework 3
Venn diagram Set Theory, Logic, Probability, Statistics 3
Really Need Help with this venn diagram! General Math 5
