Register to reply
Basic torque fulcrum problem assitance needed
by PsychonautQQ
Tags: assitance, basic, fulcrum, torque
Share this thread:
PsychonautQQ
#1
Jun30-13, 07:56 PM
P: 355
A uniform rod with a length of 10 meters and a mass of 20 kilograms has a 20 kilogram mass on one end and a 40 kilogram mass on the other end. Where should the fulcrum be located for this beam to balance?
________________
| V |
|20kg| |40Kg|
2. Relevant equations
Torque = Force * Radius
3. The attempt at a solution
Usually when i did problems like this i'm pretty sure the board was considered mass-less, and i'm not sure how to do it now that it has mass. Is calculus needed?
Anyway, lets consider:
20 kg mass = m1 @ r1
40 Kg mass = m2 @ r2
and then to figure in the boards mass can we just consider it to have a center of mass on each side (that obviously depends on where the fulcrum is)?
if so....
Left side of board = m3 @ r3
right side of board = m4 @ r4
(m1g*r1) + (m3g*r3) - (m2g*r2) - (m4g*r4)=0
m1g + m2g + m3g + m4g = Normal force of fulcrum
Anyway i'm a little stuck obviously ..
Phys.Org News Partner Science news on Phys.org
Mysterious source of ozone-depleting chemical baffles NASA
Water leads to chemical that gunks up biofuels production
How lizards regenerate their tails: Researchers discover genetic 'recipe'
dreamLord
#2
Jun30-13, 08:46 PM
P: 203
You can assume the rod to be a point particle with mass 20kg located at it's center of mass, since that's where gravity can be assumed to be acting.
In your method, the torque due to 'm3' and 'm4' (about the center of the rod) will be the same in magnitude, but opposite in direction, and will cancel out.
PsychonautQQ
#3
Jun30-13, 09:18 PM
P: 355
Quote Quote by dreamLord View Post
Oh okay cool. So i now have two equations m1gr1 + m2gr2 -m3gr3 = 0
and
m1g+m2g+m3g = Normal force of fulcrum (not sure if this equation is useful)
I'm just trying to figure out a systematic way to solve this problem, i could plug in numbers and play the "hotter and colder" game until i get something that fits but i want to find a method more mechanical.
SteamKing
#4
Jun30-13, 10:12 PM
Emeritus
Sci Advisor
HW Helper
Thanks
PF Gold
P: 6,471
You are just writing equations without giving thought to finding the desired location of the fulcrum. The equations you have, while strictly correct, are not leading you towards finding the location of the fulcrum which balances the rod.
Assume:
x - the location of the fulcrum from the left end of the rod (this choice is arbitrary)
Let's also say that the 20 kg mass is on the left end of the rod, and the 40 kg mass is on the opposite end.
We are using masses here, but the requirement for the rod to be in equilibrium means that the forces acting on the rod must balance, just as the total torque acting on the rod at the fulcrum must equal zero.
Write the torque equation using the fulcrum as a reference point. When you plug in the known quantities into the torque equation, you should have one equation with one unknown, namely x, the location of the fulcrum. Solve for x, and Bob's you uncle.
PsychonautQQ
#5
Jul1-13, 09:18 AM
P: 355
Quote Quote by SteamKing View Post
Assume:
Thanks a ton! does this look correct to you?
m1g*x - m2g*(10-x) + m3g * (x-5)
where m3 is the mass of the board. Btw bob is my uncles name and i didn't know that was a saying I was like wtf haha
dreamLord
#6
Jul1-13, 11:31 AM
P: 203
Looks correct to me.
Register to reply
Related Discussions
Basic torque problem Introductory Physics Homework 1
Solving Torque in Stretcher/Paramedic Problem-Unsure About Fulcrum Classical Physics 1
Torque Problem Help Needed Advanced Physics Homework 0
Two Different Masses on an Uncentered Fulcrum (Torque) Introductory Physics Homework 2
Torque, Rod Balanced on Fulcrum Introductory Physics Homework 1
