Light going through glass to make a rainbow
  • Context: Undergrad
  • Thread starter Thread starter relativitydude
    Glass Light Rainbow
The discussion revolves around the phenomenon of light passing through glass and the conditions under which a rainbow effect might be observed. Participants explore the implications of beam width, chromatic dispersion, and the refractive properties of glass.
  • Exploratory, Technical explanation, Conceptual clarification
  • One participant suggests that a very thin beam of white light, specifically one millimeter or even one micrometer, could produce a rainbow effect when passing through a meter of glass due to different frequencies refracting at different angles.
  • Another participant questions the feasibility of this idea, arguing that even a micrometer-wide beam would likely overlay back into white light due to the numerous points of interaction with the glass.
  • A third participant states that the width of the resulting rainbow would primarily depend on the chromatic dispersion of the glass.
  • One participant seeks clarification on the term "chromatic dispersion."
  • A later reply defines chromatic dispersion as the phenomenon where the index of refraction of a material varies with the wavelength of light, leading to a rainbow effect in most materials.
Participants express differing views on the necessary beam width for producing a rainbow effect, indicating that multiple competing perspectives remain unresolved.
There are assumptions regarding the properties of the glass and the nature of light interaction that have not been fully explored, particularly concerning the impact of beam width on the resulting optical effects.
relativitydude
Someone in a physics class here proposed, a white light beam going through a meter worth of glass and because different frequences refract at different angles, a 1 cm rainbow would come out the other end. The only way I see this to be possible is for the beam to be infinetely thin. I mean REALLY THIN.
(He even says a 1mm beam would be thin enough to product a rainbow affect)
I think, however, even a beam of one micrometer the light would overlay back into white light because the vast number of points where the light strikes the glass.
Science news on Phys.org
No one know? :(
The width of the rainbow would depend on the chromatic dispersion of the glass more than anything.
Claude.
What is this chromatic dispersion?
Chromatic dispersion is where the index of refraction of the material depends on the wave length of the light, i.e. it is not a constant. Most materials index of refration depends on wavelength, so you will see a rainbow effect.
  • · Replies 40 ·
  • · Replies 207 ·
16K
  • · Replies 24 ·
