Calculating Slit Width for Diffraction Pattern
The discussion focuses on calculating the slit width for a diffraction pattern produced by a single slit using monochromatic light with a wavelength of 500 nm. Given the distance from the slit to the screen is 140 cm and the distance from the central maximum to the first order maximum is 3 mm, the slit width is calculated using the formula d = (m * λ)/sin(θ). Substituting the values, the slit width is determined to be approximately 0.0233 mm, indicating the necessity of a narrow slit for clear diffraction patterns.
  • Understanding of diffraction patterns and their formation
  • Familiarity with the wave nature of light
  • Knowledge of trigonometric functions and their application in physics
  • Ability to manipulate and convert units (e.g., nm to mm)
  • Study the principles of diffraction and interference in wave optics
  • Learn to apply the formula d = (m * λ)/sin(θ) in various scenarios
  • Explore the effects of slit width on diffraction patterns
  • Investigate advanced topics such as multiple slit interference and diffraction gratings
Students and professionals in physics, particularly those focusing on optics, as well as educators teaching wave phenomena and diffraction concepts.
Jacob87411
A diffraction pattern is produced on a screen 140 cm from a single slit using monochromatic light of wavelength 500 nm. The distance from the center of the central maximum to the first order maximum is 3 mm. Calculate the slit width (assume first order maximum is halfway between the first and second order minima).
So things we know-
From the slit to the screen is 140 cm
Wavelength = 500 nm
from the center of the central maximum to the first order is 3 mm.
if we use: Sin of the angle = (M * Wavelength)/d =
sin of the angle = (1 * 500x10^-7) / .003
That gives the angle of the central maximum which we can then plug into
sin angle=wavelength/slit width?
Does this look right or did i go wrong somewhere? Any help is appreciated greatly
To calculate the slit width, we can use the formula d = (m * λ)/sinθ, where d is the slit width, m is the order number, λ is the wavelength, and θ is the angle from the central maximum to the first order maximum. In this case, we are given the values of m = 1, λ = 500 nm, and θ = 3 mm/140 cm = 0.0214 rad. Plugging these values into the formula, we get:
d = (1 * 500x10^-9)/sin(0.0214)
= (500x10^-9)/0.0214
= 0.0233 mm
Therefore, the slit width is approximately 0.0233 mm. This means that the slit should be very narrow in order to produce a diffraction pattern with distinct and well-separated maxima and minima.
  • · Replies 34 ·
