What are the accepted theories for the source of gravity?
In summary, both Newton's and Einstein's theories of gravity are still in use, though Einstein's equations are more commonly used. There is a difference in how gravity behaves when compared to the surface vs. inside of a body, and the GPS system takes into account gravitational time dilation.
ZionsRodeVos
I have very little knowledge of physics so the simpler you can keep your replies the better for me.
Newton put forth a gravity theory that essentially said that there is a force that pulls on us to keep people on the Earth and this is gravity.
Einstein came along and included in his theory of relativity that there is not a force that pulls on us but that because massive objects such as the Earth bend/warp space that there is no pull on us but space is pushing us toward the earth.
I'm not generally a skeptical person and so put it to my lack of knowledge as the reason I don't really believe space is pushing me toward the earth. But I am not here to argue that Einstein is wrong but to understand this part of his theory better.
Did Einstein's theory about gravity make Newton's obsolete and so no longer valid nor used?
Are there other theories on what the source of gravity is?
Who is it that first thought that everything with mass has gravity?
Both Newton and Einstein developed theories that told how to calculate the force of gravity. Neither said anything ablut "the source of gravity" nor does any modern theory. (Some theories deal with "gravitons" but that still does not say anything about the source of gravitons.)
I thought that Einstein indicated that he believed that space pushes us toward the earth. Is that wrong? And that is what I took to indicate the source of gravity in the case of his theory.
I do remember from a documentary about Newton that he believed gravity was a pulling force without saying where that pulling source came from.
Is there a specific theory name that I could look up that would explain more about these graviton's? I've come across reference to graviton's once or twice in the few weeks I've been researching physics.
Yes, that's wrong. The warping of space isn't really meant to indicate that space is a "thing" that pushes on matter.
Yes.
Just googling for gravitons will get you a lot of info. Starting with the wiki: http://en.wikipedia.org/wiki/Graviton
That is incomplete. It's not just space that warps but space-time. Absent any forces, everything has a constant velocity through space-time. If you are sitting still, all your velocity is in the time direction. If you move through space you move less through time. Gravity is the twisting of the space-time framework so that forward in time is also downward. Slightly downward in the case of the earth, straight down in the case of a black hole. Please note that this is an extreme simplification. Einstein would likely be appalled, but it's the best I can do in 1 paragraph.
Thanks. This gives me more to think about and more to research. I didn't quite think of Einsteins theory in that way.
And I still need to read more about gravitons.
Are both Newtons and Einsteins equations to calculate gravity still in use? Or did Einsteins replace Newtons?
Newton's equations are still used ubiquitously in physical applications.
Newton's equations are used in almost all instances because they are much simpler then Einstein's and almost as accurate. NASA uses Newtonian gravity to plan it's mission.
Einstein's equations are used mostly for theoretical work dealing with extreme circumstances like the BB, black holes, etc. The differences do become significant in extreme circumstances.
The 1 exception that I can think of is the GPS system which must take gravitational time dilation into account in order to achieve the extreme accuracy of time keeping necessary to make it work. Each 0.000000003 seconds of error in time keeping represents about a meter in position.
mrspeedy "The 1 exception that I can think of is the GPS system which must take gravitational time dilation into account in order to achieve the extreme accuracy of time keeping necessary to make it work."
There does exist another significant exception: in the case of nuclear submarines which must spend long periods of time on the ocean floor, closer to the center of the earth. They are
required to modify their clocks due to the stronger gravity there, so that the delicate missile behaviours can be accurate. Sending a missile to the wrong place would be a 'no-no' , no?
Thanks! You're answers help me to understand better as to how both could be in use when I was thinking it should be one or the other.
What level of calculus would I need to understand the formula's you posted. I know I took the first year of calculus but don't remember mention of its use in gravity calculations and of course I remember almost none of it now since I haven't used it in more than 20 years.
What does BB stand for?
Big Bang. :smile:
You need to be careful when trying to establish the "why"s that are involved in Science. Unless you are going to postulate a 'God' who set up a load of rules then all you can ever really hope to do is to devise models that predict the way things will work within certain limits. Newton was no more wrong than Einstein and Einstein was not ultimately 'right'. There's no end to it.
It is easy to feel superior to our scientific predecessors who assumed that there were actual 'Laws', literally, at work but 'they' were building on top of their religion and trying to improve on Genesis 1 etc.. We have loads of questions that will always be unanswerable without using further 'shells' of understanding which, themselves, will throw up more new questions.
Now I feel dumb not realizing that BB was for the big bang. Thanks for giving me the meaning!
I am actually curious to see what aspects of physics is found in the scriptures and how much is similar and how much is different. I don't remember reading anything about gravity in the scriptures but that could be because I was never really focused on that whereas now I am. I remember reading things in the site rules about religion and am not sure how much of what I believe concerning God and the laws of physics I am allowed to discuss here.
In fact I was very worried that my first question here would suffer the fate of other questions mentioned in the rules and sticky threads.
I am convinced there are questions we may never find the answer too, but was hoping that the source of gravity was not one of those and that I was simply missing something because I didn't know what terms to use in a search or because there was so much info that I'd have a lot of trouble finding what I am looking for.
Your best bet is to simply not talk about scriptures at all. I've been on the site for almost 3 years now and not once have I ever seen a productive thread that had any mention of religion in it. Also, to my limited knowledge, there is absolutely nothing that could be considered "accurate physics" in any religious text. Otherwise we wouldn't have had to start from scratch all those years ago.
Why stop at gravity? There are four total fundamental forces, and we don't know the "source" of any of them. But, as has been explained, there really isn't an end to the "why" question. You can keeping asking why forever, as each time you answer one question a new one immediately pops up.
A driving force for my interest in gravity is to better understand it so that a science fiction book I am writing may be more realistic. That is at least what sparked my interest but there seems to be more to it than that at this point and so I keep reading and listening to documentaries and such on you tube. So I haven't tried to investigate the other forces but have come across them while trying to learn about gravity.
And up until you said that, I didn't realize the other forces also had unknown sources.
I've read and listened to more about gravitons and while it is interesting and difficult to understand for me at first they still leave me with questions.
Is there any person or people that are credited with a theory that includes gravitons? Like Einstein is credited with developing the theory of relativity.
What are you going to do with this knowledge in your book? Just use it to make things more realistic, or are you delving into explaining gravity in some way?
As I said, the question of "Why" something works or what's the "source" of something is never ending. For example, if I asked you why things have mass, how would you explain it? The only possible answer anyone can give you is "They just do." This goes for all sorts of properties. From spin, to charge, and any other fundamental property or force there is.
I don't know, sorry.
I just read a thread here about artificial gravity and depending on how I decide to do things this knowledge could help me make a different kind of artificial gravity. However, my initial reason for trying to understand it was so that I can have a feasible way for a large object to shut off its natural gravity and/or have gravity function differently than what we know here on earth.
And you just hit on another problem I am starting to delve into which is about mass. I don't have enough knowledge to know why things have mass but I am going to investigate differences in mass and get a better understanding of mass also.
There is no feasible way for that to happen. Period.
However, that's why it's Science Fiction and not Science Fact!
I'll tell you why things have mass.
They just do.
If you really want to feel good about any small increase in your understanding of the World, that involves getting down to some real Rigour. The pleasure you can get from learning absolute basics and using that to derive even the most fundamental 'new thing' (that is 'new for you') is just incredible. It beats all that arm waving and mystical phoney Science. In the end it's down to nuts and bolts and getting the lamp to light up or the solution to change colour as you predicted. All the rest is metaphysics and philosophy - angels on pinheads etc.. Try to swim around out of your depth in Science and you'll drown before you get anywhere. (Imho, of course)
To use Newtonian gravity you should have a basic understanding of integration. When I took calculus I had 1 semester of differentiation and 1 semester of integration. If your course was similar then you've probably been exposed to all the calculus you need for Newton, though you'll probably need some refreshment after 20 years
To use Einstein's equations you need a solid understanding of tensor calculus. This is beyond my abilities right now and apparently it's pretty advanced stuff. When I first discovered I needed to learn it I asked my father to teach me because he has a masters degree in mathematics. He didn't know what a tensor was. (In his defense it has been 40 years since he graduated)
They just do.
Ah but if I remember correctly from a documentary I listened to, at the quantum level they believe they can do teleportation. If that can be done at a larger scale then mass could be teleported elsewhere temporarily, thus shutting off gravity because of the reduced mass and then teleported back.
Also what if in the CERN collider they discover a graviton and then learn how to create them consistently. They may be able to create artificial gravity that way by generating enough gravitons.
I intend to do experiments as a way to gain experience that I won't get by just talking about physics but I have not done many at this point as I want a bit more knowledge first.
Thanks! I'll have to review integration calculus and then move on to tensor calculus. Can I safely ignore differentiation calculus if I am only interested in Newton's gravity equations?
No, this is not possible. That is not what Quantum Teleportation is nor would it work that way.
http://en.wikipedia.org/wiki/Quantum_teleportation
Not true. Generating real, physical gravitons would not cause artificial gravity. This is similar to the fact that generating large numbers of real photons does not generate a sustainable electric or magnetic field. The graviton, if it exists, would be the mediating particle of the gravitational field, much like photons are the mediators of the electromagnetic field. But it is virtual particles that mediate these fields and their forces, not real ones. I'll leave it to someone else to explain why, as I am not familiar enough with virtual particles to adequately explain it.
The best way to get started on this is to learn the basic fundamentals and the corresponding math and move up from there. AKA you start with Physics 101 or whatever and move on from there. I guarantee you that if you really want to understand physics, there is no better way. Absolutely no amount of watching popular science videos or reading popular science books will teach you anything close to what a single textbook on physics will if you put in the effort to learn it.
Tell me if I am wrong, but I think that there is no current logical & rational theory for the source of gravity.
I remember reading a book by John Barrows, a mathematician at Cambridge, titled "The Constants of Nature". In this book, he says that the constants are quite mystical. He says that all the physicist really works on are their properties and being calculable.
If their is a theory around the constant of gravity, please tell me! I apologize of my grammar. English is not my first language.
Hey Z.R.V., it sounds like you are asking two questions here.
1) How does gravity as we understand it work?
2) What sort of a scifi argument could I make for artificial gravity and a mechanism for cancelling a gravitational field?
If you want to deeply understand the first question, starting from Newton's theory you can start with just algebra and geometry, but calculus is important. Differential and integral calculus should both be understood well as you dive deeper. If you want to understand Einstein's theory, you will need a MUCH deeper mathematical background than you will for Newton's. That being said, there are quite a few decent laymen's explanations.
For questions 2, you should probably not try to find an explanation with the current understanding of gravity. The only artificial gravity mechanism that I have heard of that works within the framework of our current knowledge is a rotating ring that uses a centrifugal force to mimic gravity.
Perhaps you would be better off making up some sorts of exotic materials that could help. Note: none of the following ideas have any basis in science fact.
If there exists some material with a negative mass, one might be able to create "shields" that would cancel out the gravitational force outside of the shield.
http://en.wikipedia.org/wiki/Negative_mass
In the other direction, you could pretend that people can construct extreme density materials into long sheets. Near the center of the sheets, there would be a nearly uniform gravitational field (near the edges though, you might be ripped apart)
Both of these ideas could be reasonably be considered with Newtonian gravity (although this does depend on the density of the material). It would be best to have an understanding calculus, but some geometric intuition and algebra might be enough.
Again, I have no reason to believe that either of these could be possible. It seems unlikely to me that there is such a thing as negative mass, but the beauty of scifi is that reality doesn't matter.
Integration is the reverse operation of differentiation except that it is much more difficult. Until you can differentiate in your sleep you have 0% chance of successfully mastering integration. The good news is that you can get computer software to do both of these things for you so they are less tedious. The bad news is that you still have understand how to differentiate and integrate functions in order to understand what the software is doing and how to use it.
Not even in the slightest. Differential calculus is at the heart of physics. Knowing the theory of the calculus, both integral and differential, is extremely important for a proper understanding of classical gravitation; computations have their use as well but compared to theory they are just mind numbingly boring (and trivial on the differential side). I wouldn't worry about tensor calculus for now; you need more than just calculus for that.
mrspeedybob said:
T. . . . . .When I first discovered I needed to learn it I asked my father to teach me because he has a masters degree in mathematics. He didn't know what a tensor was. (In his defense it has been 40 years since he graduated)
You youngsters. Do you really think Tensors are a new invention? :biggrin: I 'did' them in the 60s and was just as confused as modern students, by this bit of Maths. You just need to learn how to handle them - the same as with vectors and matrices - and follow the rules
I'll need to learn more about quantum teleportation. Thanks for the link. I listen to a lot of documentaries and lectures on you tube because I can do that while working.
Are there any textbooks online?
It is true that I feel understanding gravity will help me with my book but since the interest came it has moved beyond just learning about gravity for the sake of the book. My mind often dwells on this as I try to understand. Yesterday or today I realized that with the theory of relativity the reason gravity decreases as you move toward the core of the planet would be because the warp in space is getting less because there is less mass at the center of the planet versus on the surface where the warp in space time should be more.
Those are good ideas for how to control gravity in a sci-fi book.
And as for calculus when I get to that I will learn both differential and integration.
I don't think this is correct at all. The amount of mass near the Earth's surface (Depending on what "near" means), is far exceeded by the amount of mass in the outer and inner core of the Earth (where 25-35% of the Earth's mass is located).
The reason why gravity drops off is because you start having more and more mass AROUND you instead of UNDER you, so the pull in every direction starts to equal out. At the Earth's [STRIKE]surface [/STRIKE] core the curvature of spacetime due to mass should be at its greatest.
The reason why gravity drops off is because you start having more and more mass AROUND you instead of UNDER you, so the pull in every direction starts to equal out. At the Earth's surface the curvature of spacetime due to mass should be at its greatest.
I just realized I probably should have put that part about Einstein's general relativity in my other thread. Only two threads and I'm already getting them confused. I'm going to spend some time thinking about how I would feel if gravity were to pull on me from every direction at the same time and same force.
Don't think of things in terms of space-time curvature; it's going to be utterly confusing for a problem that involves the gravitational force within the Earth; don't make things more complicated than they need to be.
  • #31
I believe you would feel like you were weightless and in freefall.
  • #32
Are you sure you're sure you're sure about this? How about the curvatures all cancelling out in the middle?
  • #33
Wait... my post says greatest at the surface. I think I meant at the core.
Which one did you mean?
Also, we might want to avoid talking GR in this thread, it's getting really messy.
  • #34
In September 1905, Albert Einstein published his theory of special relativity, which reconciles Newton's laws of motion with electrodynamics (the interaction between objects with electric charge). Special relativity introduced a new framework for all of physics by proposing new concepts of space and time. Some then-accepted physical theories were inconsistent with that framework; a key example was Newton's theory of gravity, which describes the mutual attraction experienced by bodies due to their mass
  • #35
Most effects of gravity vanish in free fall, but effects that seem the same as those of gravity can be produced by an accelerated frame of reference. An observer in a closed room cannot tell which of the following is true:
*Objects are falling to the floor because the room is resting on the surface of the Earth and the objects are being pulled down by gravity.
* Objects are falling to the floor because the room is aboard a rocket in space, which is accelerating at 9.81 m/s2 and is far from any source of gravity. The objects are being pulled towards the floor by the same "inertial force" that presses the driver of an accelerating car into the back of his seat.
  • Other Physics Topics
  • Beyond the Standard Models
