An upside down rocket
by smarthimandrew
Tags: rocket, upside
smarthimandrew
smarthimandrew is offline
#1
Jul5-13, 02:19 PM
P: 1
If I were to take a model rocket and secure it upside down to a kg scale, what would I be reading on the scale's display? I would assume it would be the thrust of the rocket but are there other factors at play here? If it is the thrust of the rocket, how would I convert the said value to newtons?
Phys.Org News Partner Physics news on Phys.org
Physicists consider implications of recent revelations about the universe's first light
Vacuum ultraviolet lamp of the future created in Japan
Grasp of SQUIDs dynamics facilitates eavesdropping
bigfooted
bigfooted is offline
#2
Jul5-13, 02:32 PM
P: 265
You can draw a free body diagram to analyze the forces on the rocket.
The trust vector is pointing down, as well as gravity: F + m*g.
EDIT: assuming you measure this on earth and not in space
russ_watters
russ_watters is offline
#3
Jul6-13, 08:23 AM
Mentor
P: 22,006
Model rocket engine thrust is published - you can just look it up. And a typical scale measures force and converts to mass by assuming you are on the surface of the earth and applying f=ma. So it is easy enough to convert back.
CWatters
CWatters is offline
#4
Jul6-13, 05:48 PM
P: 2,861
Put rocket on scale pointing downwards.
The display will read the weight of the rocket in Kg.
Press the reset button on the scales so they read zero.
Light the rocket and the scales will read the thrust in Kg.
To convert to Newtons multiply by 9.8.
Edit:
I'm not an expert but model rocket motors are classified by the impulse they produce. The impulse is the force * duration.
So for example a Class B that is rated 5.00 NĚs might produce..
5N for 1 Second
2.5N for 2 Seconds
1N for 5 Seconds
etc
They would all be Class B I believe.
I've yet to find a model shop that will sell me a 6Z class motor.....
http://en.wikipedia.org/wiki/Model_r...classification
Register to reply
Related Discussions
Upside down. Cosmology 4
How do aircraft fly upside down? Mechanical Engineering 20
what does the upside down T mean Math & Science Software 2
water in upside down cup Classical Physics 9
upside down recipe General Discussion 11
