Oxidation Reduction (redox) Balancing
In summary, when balancing oxidation reduction reactions involving acids or bases, H+ ions can be added to one side of the reaction and H2O to the other, or OH- and H2O can be added to balance out hydrogen and oxygen. This is due to the ability of H+ to grab oxygen atoms and form H2O, similar to how 2OH- can supply oxygen atoms. However, it is more appropriate to use the hydronium ion, H3O+. These reactions typically take place in water with plenty of H2O and H+/OH- present, allowing them to be added between reactants and products without affecting their concentrations.
krackers
72
When balancing oxidation reduction reactions involving acids or bases, what (in the case of acids) allows you to add H+ ions to one side of the reaction and H2O to the other, or in the case of bases, OH- and H2O to balance out hydrogen/oxgen? Normally you are not allowed to just add random compounds to either side of the equation.
I suspect this has something to do with the ability of H+ to grab oxygen atoms to form H2O, as similarly with 2OH- to supply Oxygen atoms and give H2O, as demonstrated by these two reactions:
[itex]2H^{+}\; +\; O^{2-}\; -->\; H_{2}O[/itex]
[itex] 2OH^{-}\; -->\; H_{2}O\; +\; O^{2-} [/itex]
However, is this the real reason? And instead of using H+ ions for the acids, wouldn't it be more appropriate to use the hydronium ion, H3O+?In case the question is not clear, here is an example reaction.
[itex]MnO_{4}^{-}\; +\; I^{-}\; -->\; I_{2}\; +\; Mn^{2+}[/itex]
One of the half reactions would be:
[itex]5e^{-}\; +\; MnO_{4}^{-}\; +\; 8H^{+}\; ->\; Mn^{2+}\; +\; 4H_{2}O[/itex]
However, in this half reaction what allows you to add H+ to one side and H2O to the other?
Chemistry news on Phys.org
These reactions usually take place in water, and typically in either low or high pH - so you can safely assume there is plenty of H2O and H+/OH- around. As there is plenty of them, they can be between reactants and products and you won't even notice changes in their concentrations.
1. What is oxidation reduction (redox) balancing?
Redox balancing is a chemical process that involves balancing the number of electrons gained and lost in a chemical reaction. This is done by assigning oxidation numbers to the atoms involved and making sure the overall charge is balanced.
2. Why is redox balancing important?
Redox balancing is important because it allows us to accurately predict the products of a chemical reaction and understand the changes in the oxidation states of the atoms involved. It is also essential in industrial processes, such as in the production of metals and in environmental processes, such as in the breakdown of pollutants.
3. How do you balance a redox reaction?
To balance a redox reaction, you first need to identify the atoms undergoing oxidation and reduction. Then, assign oxidation numbers to each atom and determine the change in oxidation number. Use coefficients to balance the number of atoms on each side of the reaction and then balance the charges by adding electrons. Finally, check that the atoms and charges are balanced on both sides of the reaction.
4. What is the difference between oxidation and reduction?
Oxidation is the process of losing electrons, while reduction is the process of gaining electrons. Oxidation and reduction always occur together in a redox reaction, and the total number of electrons lost must equal the total number of electrons gained.
5. Can all chemical reactions be balanced using redox balancing?
No, redox balancing can only be used for reactions where there is a transfer of electrons between reactants. Reactions involving only covalent bonds, such as hydrocarbon combustion, do not involve a transfer of electrons and cannot be balanced using redox balancing.
  • Chemistry
  • Chemistry
