Question about hypothesis testing
The discussion clarifies the application of the z-test formula in hypothesis testing, specifically addressing the confusion surrounding one-sided and two-sided tests. The z-test formula, (y - u)/(sigma)/(sqrt(n)), is utilized to calculate the z-score, which is compared against critical values to determine statistical significance. For one-sided tests, the alpha level is set directly to the desired significance level, while for two-sided tests, the alpha level is divided by 2 to account for both tails of the distribution. This distinction is crucial for accurately interpreting hypothesis testing results.
  • Understanding of z-test formula and its components
  • Knowledge of statistical significance and alpha levels
  • Familiarity with one-sided and two-sided hypothesis testing
  • Basic concepts of normal distribution
  • Study the application of the z-test in various statistical scenarios
  • Learn about the differences between one-sided and two-sided tests in depth
  • Explore the implications of alpha levels in hypothesis testing
  • Investigate the use of statistical software for hypothesis testing
Statisticians, data analysts, students in statistics courses, and anyone involved in hypothesis testing and statistical analysis.
semidevil
i'm getting my concepts very confused now...
so the formula for the normal distri is (y - u)/(sigma)/((sqroot(n)).
so if I want to test y, I set that formula = to alpha(where alpha is the confidence level).
that is if it is one sided. if it is 2 sided, do I still set it to alpha, or alpha/2?
i'm pretty sure if it's 2 sided then you set it to [tex]\frac{\alpha}{2}[/tex]
It is understandable to feel confused about hypothesis testing, as it can be a complex topic. However, it is important to clarify some concepts to better understand the formula and how to use it in hypothesis testing.
Firstly, the formula you mentioned is the formula for the z-test, which is used to test hypotheses involving a population mean when the population standard deviation is known. This formula is used to calculate the z-score, which is then compared to a critical value to determine the statistical significance of the results.
Secondly, when conducting a one-sided test, the alpha level is typically set to the desired level of significance (e.g. 0.05 or 0.01). This means that the calculated z-score needs to be equal to or greater than the critical value in order to reject the null hypothesis. However, for a two-sided test, the alpha level is divided by 2 and used for both tails of the distribution. This is because a two-sided test is concerned with the possibility of a significant difference in either direction, so we need to account for both tails of the distribution.
In summary, for a one-sided test, the formula is set equal to the alpha level, and for a two-sided test, the formula is set equal to alpha/2. I hope this helps clarify your confusion about hypothesis testing. Remember to always carefully consider the type of test you are conducting and the appropriate alpha level to use.
  • · Replies 95 ·
  • · Replies 21 ·
