A.B= m1, B.A=m2, m1 and m2 diagonal matrices
  • Context: Graduate
  • Thread starter Thread starter arivero
    Matrices
The discussion revolves around the parametrization of pairs of n x n matrices A and B such that their products yield diagonal matrices m1 and m2. Participants explore conditions under which these matrices can be diagonal or non-diagonal, particularly focusing on the implications of the commutator [m1, m2] being non-zero.
  • One participant seeks clarification on how to parametrize pairs of matrices A and B such that AB = m1 and BA = m2 yield diagonal matrices.
  • Another participant notes that if m1 and m2 are diagonal with no zero eigenvalues, they share the same eigenvalues, raising questions about the conditions when they are not simultaneously diagonal.
  • There is a discussion about the triviality of the case when the commutator [m1, m2] equals zero, with a focus on the more complex scenario when it does not.
  • One participant suggests that assuming m1 is diagonal simplifies the problem, while another challenges this assumption, stating that diagonal matrices commute and thus cannot fulfill the original conditions.
  • Clarifications are made regarding the invertibility of matrices A and B, with one participant stating that only one needs to be invertible for certain properties to hold.
  • It is noted that the eigenvalues of AB and BA are the same, and this leads to a classification of cases when one of the matrices is invertible.
  • Another participant connects the discussion to the context of Weyl bi-spinors, suggesting implications for mass in particle physics.
  • Further exploration of the cyclic properties of matrices and their characteristic polynomials is introduced, questioning the nature of cyclic invariants related to traces and determinants.
Participants express differing views on the assumptions regarding the diagonal nature of matrices and the implications of the commutator. While some points are clarified, the discussion remains unresolved regarding the general case of parametrizing A and B under the specified conditions.
There are limitations regarding the assumptions made about the matrices, particularly concerning their diagonalizability and invertibility. The discussion also reflects uncertainty about the implications of the commutator and the conditions under which the matrices can be classified.
arivero
can anybody refresh me on this? I would like to parametrize the pairs of n x n matrices such that the products (A . B) and (B . A) give diagonal matrices of real coefficients. I get lost already for n=3.
Hmm, ok, if m1 and m2 are diagonal and having no zero eigenvalues, it seems easy to proof that they have the same eigenvalues.
Now, what happens if there are not simultaneusly diagonal, ie when the commutator [m1,m2] is different of zero? Is it possible to have an A,B pair? Under what conditions?
What does "an A,B pair" mean?
Srill as in the subject and the first post: a pair of square nxn matrices such that AB=m1, BA=m2.
The case with the commutator [m1,m2]=0 seems rather trivial, but I am still wondering how to attack the general case when [m1,m2] <>0.
Surely we can assume m1 diagonal, without losinge generality.
Erm, all diagonal matrices commute with each other, so it can't be like "still as in the subject" and of course you can't assume that m1 is diagoneal, or m2. Why do you think AB must be diagonalizable? As I said, you've changed to some other unspecfied task: classify pairs of matrices A and B such that ... only yo'ure not saying what the ... is.
You are right, matt :-) overnight I noticed that the case in the subject was rather trivial, amounting to a permutation of the eigenvalues. So I tweaked the requeriment to have only one diagonal, say m1, and asking [m1,m2]<>0 (thus the other is not diagonal). Still, A and B are defined as in the subject, AB=m1, BA=m2. I have removed the other condition, simultaneus diagonal of m1, m2.
Which I am asking is to find and parametrize pairs of matrices A, B. Or, equivalently, to classify pairs of matrices A and B such that "there exist m1, m2 with AB=m1, BA=m2, [m1,m2]<>0 and m1 diagonal".
Ok I figured it, at least for the non degenerate case with |A| and |B| different of zero. Then AB and BA have the same spectrum of eigenvalues. (I didn't know it, I thought they shared just Det and Tr)
BTW, has this theorem got a name?
I don't know if it has a special name, but you don't require both A and B to be invertible. It suffices for one of them to be invertible. Wlog A is invertible, then
AB-xI = A(BA-xI)A^{-1}
taking dets on both sides gives me x is an eigenvalue of AB iff it is an eigenvalue of BA.
Thus AB=m(1) and BA=m(2) implies A^{-1}m(1) =m(2)A^{-1} or equivalentky the m's are conjugate. This completely classfies the case when one of A or B is invertible.
Yep, that is. So we have proved that any family of massive Weyl bi-spinors is composed of pairs of equal mass spinors (AB and BA being the mass square of the right and left spinors). I'll think about the degenerate case (which could happen if still a neutrino has zero mass).
Furthermore, as AB and BA have the same characteristic polynomial, the same can be said of any cyclic pair A.B.C...E.F, B.C...E.F.A. Thus the ciclic property of the trace is generalised to any of the coefficients of the characteristical polinomial: writing
[tex] |Q- \lambda I_n|= \lambda^n + \tau_{n-1}[Q] \; \lambda^{n-1}+...+ \tau_1[Q] \; \lambda+ \tau_0[Q][/tex]
we get n "ciclic invariants". Guess [tex]\tau_{n-1}[Q][/tex] is (a multiple of) the trace and [tex]\tau_0[Q][/tex] the determinant, isn't it? Or do they appear as more complicated combinations?
