What is the Force per Meter on Conductor C in a Three-Phase Transmission Line?
The discussion revolves around calculating the force per meter on conductor C in a three-phase transmission line, where conductors are arranged in an equilateral triangle. The problem involves understanding the interactions between the currents in the conductors and the resulting magnetic fields.
  • Participants discuss the magnetic field generated by conductors A and B and its effect on conductor C. There is an exploration of using the H field and the force equation involving the cross product of current and magnetic field. Questions arise about the role of the current in conductor C and its influence on the magnetic field at that point.
The discussion is active, with participants sharing their thoughts on the equations that may apply and questioning the assumptions regarding the magnetic field interactions. Some guidance has been provided regarding the force equation and the relationship between the currents in the conductors.
Participants are considering the geometry of the setup and the distances between the conductors, which are critical to the calculations. There is also a focus on the specific currents flowing through each conductor and how they relate to the magnetic fields generated.
formulajoe
a three phase transmission line consists of three conductors that are supported at points A,B, c to form an equilateral triangle. At one instant, conductors A and B both carry a current of 75A while conductor C carries a return current of 150 A. Find the force per meter on conductor C at that instant.
heres what it looks like
A
|-------C
B
current at A and B is going in, current at C is coming out. Each point is 2 meters apart.
This is the z = 0 plane
im really stuck on this one.
Where are you stuck, what have you tried?
Spit out some equations you think might fit.
the only think i can think of is to find the H field about A and B with rho being equal to the distance to C. than use the int(i*dl cross B). do that at A and B ? i don't see how the 150 amp current causes a force at C.
The force on a charge due to magnetic field from each wire will be:
[tex]F = i\int{B\times dl}[/tex]
Now you'll want to find the force for wires A and B at point C. Does the current through C affect the magnetic field? How so?
since the current at C is twice at the current at A and B than wouldn't that cancel out the magnetic field?
  • · Replies 40 ·
  • · Replies 23 ·
  • · Replies 27 ·
  • · Replies 25 ·
